Posted: Sat Apr 30, 2011 6:35 am |
ive got the standard 1 line display . clock date/radio can you change it to the 3 line mfd ? if so is it just a case of swapping the display or is there more involved?
| if it dont scuff the ruff it aint low enuf | |
Posted: Sat Apr 30, 2011 6:55 am |
No idea as you havent given the forum a clue of what type of 206 you are asking about
How do you expect help if you dont bother to give us some basic information about your car
Posted: Sat Apr 30, 2011 7:00 am |
ive got a 206 look 1.1 with the display that shows time . date radio info and i want to change it for the 3 line display that shows whats left in the fuel tank etc . is it possible to do this ?
Posted: Sat Apr 30, 2011 7:39 am |
dumdum0910 wrote: |
ive got a 206 look 1.1 with the display that shows time . date radio info and i want to change it for the 3 line display that shows whats left in the fuel tank etc . is it possible to do this ? |
Year of car would help, then it at least helps us to not guess so much.
Yes you can change it but it may involve cutting wires to change the pin locations and you won't be able to have mpg etc as you obviously need the sensors and whatever else is needed to display it.
(+ if yours is preplex it definately won't be able to have mpg)
Posted: Sat Apr 30, 2011 8:03 am |
dumdum0910 wrote: |
FFS I give up
Im not helping any more in future on threads where people cant be bloody bothered to post the full information of the car in question.
Posted: Sat Apr 30, 2011 9:06 am |
its a 2003 and its a plexed with the BSi
Posted: Sun May 01, 2011 3:28 pm |
some must of done this or must no
Posted: Sun May 01, 2011 3:31 pm |
Trade Rating: +59
Aye there is a 'how-to' if you bothered to use the Search function.
| '98 Nile Blue 306 GTi 6
'04 Obsidian Black 206 GTi 138 | |
Posted: Sun May 01, 2011 4:30 pm |
i had a look but didnt no it was called a ppt... what sensors do i need? and were do they go ?
Posted: Sun May 01, 2011 4:34 pm |
Trade Rating: +59
Do a search FFS.
Edit: Lee -
THEY SHOULD USE THE SAME PPT-40 CONNECTOR SO WILL JUST PLUG AND PLAY, YOU WILL NEED THE TEMP SENSOR ON THE N/S WING MIRROR AND THEN IF YOU WANT THE TRIP COMPUTER, YOU WILL NEED IT TURNING ON IN THE BSI AND THEN CHECK YOUR COM TO SEE IF THERE IS THE BUTTON UNDER THE CAP ON THE WIPER STALK. IF NOT, YOU NEED A NEW COM
YEAH I KNOW THIS IS IN CAPS, I COULDN'T BE ARSED TO TURN THEM OFF BECAUSE IT IS AS DIFFICULT TO TURN THESE OFF AS NOT SEARCHING, AND THEN CREATING A THREAD GIVING f*** ALL INFORMATION
GOOD DAY.
Posted: Mon May 02, 2011 2:57 am |
dumdum0910 wrote: |
its a 2003 and its a plexed with the BSi |
If only you had given that information in your first post
As for BSI ALL 206's have them, both non plexed & plexed
Posted: Mon May 02, 2011 3:16 am |
so what sensors do i need to be able to get mpg ant what ever else the multi display can show? and will the wiring be in the car already?
Posted: Mon May 02, 2011 3:47 am |
dumdum0910 wrote: |
so what sensors do i need to be able to get mpg ant what ever else the multi display can show? and will the wiring be in the car already? |
has lee just not explained it all in the post above?
Posted: Mon May 02, 2011 5:00 am |
Trade Rating: +59
*clicks watch topic*
