Posted: Mon May 02, 2011 2:43 pm |
im quite new to the 206 scene so not familar with the service intervals and the millage display to say when its due. i no the next 1 is due in 1700 miles what is required on this 1? will it be plugs . oil / petrol filter . oil and check brakes and other bits. once the service light has been reset will it then count down from 10000 miles? if so what is required on that service?
| | ![](images/spacer.gif) |
| if it dont scuff the ruff it aint low enuf | |
Posted: Mon May 02, 2011 2:44 pm |
if you have a handbook the service schedule should be in there
Posted: Mon May 02, 2011 2:47 pm |
na i dont have 1 . need to get down to peugeot and get a new 1.. then to the peugeot dealership in harlow to get it stamped up
Posted: Mon May 02, 2011 2:54 pm |
before i get moaned at again ive got a 1.1 2003
Posted: Mon May 02, 2011 2:57 pm |
Posted: Mon May 02, 2011 3:04 pm |
ok cheers. once i reset the serivice light after the 20000 mile mark will it read from 10000 miles or go back to 20000?
Posted: Mon May 02, 2011 3:26 pm |
It goes to 20. But on the how to it tells i how to change it to 10k. I left mine at the 20k went i reset it
| Abs
Peugeot 206 1.6 Sport (55)
Audi A1 2.0 TDi Sport (14) | |
Posted: Mon May 02, 2011 3:29 pm |
dumdum0910 wrote: |
im quite new to the 206 scene so not familar with the service intervals and the millage display to say when its due. i no the next 1 is due in 1700 miles what is required on this 1? will it be plugs . oil / petrol filter . oil and check brakes and other bits. once the service light has been reset will it then count down from 10000 miles? if so what is required on that service? |
Still not give enough information.. 1700 miles from what?
Mine is 9700 from a service now can you tell me what I am due next? No. ![Wink Wink](images/smiles/icon_wink.gif)
What if I said my next one would be just short of the 100k and 11 year mark? ![Wink Wink](images/smiles/icon_wink.gif)
Whats your current milage ![Wink Wink](images/smiles/icon_wink.gif)
Posted: Mon May 02, 2011 3:41 pm |
my current millege is 58000 miles and it says my next service is due in 17000 miles
Posted: Tue May 03, 2011 11:12 am |
dumdum0910 wrote: |
before i get moaned at again ive got a 1.1 2003 |
there's been so many different engines used in the 206 over the years & 2 totaly different electrical systems as well that without the exact car details you aint gonna get good useful advice
For example: Even the steering wheels are not interchangeable between the 2 different electrical systems.
If you reset the service spanner it will either go back to 18500 OR 20000 miles, depends on the BSI software version your car is running, then again it also measures time so after 2 years the spanner will flash up anyway ![Laughing Laughing](images/smiles/icon_lol.gif)
Posted: Tue May 03, 2011 11:29 am |
Service intervals? you mean that spanner that pops up? lol if I went by that I've of had a lot more services, my mechanic puts a sticker on the inside of the drivers door to with a mileage on it, when I hit that mileage, I book it for a service, simple. Speaking of which, I've just gone over it, better book it in for a service and a touch up respray before FCS
