Latest: sparrowdclxvi
Overall: 17139
Online Now [118]:
Visitors: 117
Today: 4497
Total: 113010255
Forums › The Car › 206 Problems › How do I bleed this - radiator
PostPosted: Mon May 02, 2011 4:18 am Up
Alright people,
Was going to flush out the radiator today and fill her back up. Went to open the drain screw on the radiator and there isn't the "tap" :/
Was just going to take the bottom pipe off, but surely that's going to prevent me from bleeding it
DW10TD - RHY - 2.0HDi
Gracias
PostPosted: Mon May 02, 2011 4:37 am Up
Surprised Completely unhelpful... However... You don't know?!!? Surprised
Lecktorious
PostPosted: Mon May 02, 2011 4:40 am Up
Trade Rating: +59
I think Bon did a 'how-to' Lee - think you just pull off the bottom hose and drain the radiator.
'98 Nile Blue 306 GTi 6
meady
PostPosted: Mon May 02, 2011 5:04 am Up
Trade Rating: +45
tomd0801754 wrote:
:O Completely unhelpful... However... You don't know?!!? Surprised
i was thinking exactly the same thing, if lee dont know who will Smile
TEAM - I HATE FACEBOOK Smile
DeadEyePaul
PostPosted: Mon May 02, 2011 5:06 am Up
Summon Edward the king of clean!
sonicscrewdriver
PostPosted: Mon May 02, 2011 5:13 am Up
you have to take off the bottom pipe......i had to repaire a hole in my rad friday, i thought someone nicked my tap untill i noticed it was a blank......when you refill it tho you gotta take of the dust cap on the hose going into the bulkhead to bleed it...
206gti breaking
long time since being on here last! what happened?! lol
Bigbenj_08
PostPosted: Mon May 02, 2011 5:33 am Up
Yeah I think I read in a guide somewhere on here... it mentioned to loosen the bottom hose but not remove it as it can be a PITA to get back on apparently.
Aegean Blue 1.6 16v Sport
PostPosted: Mon May 02, 2011 5:36 am Up
Strange that there is no drain plug. With the drain plug it's easy to keep it all tidy and controlled then draining it but without it the only option is to remove the hose and watch 5 litre of coolant spill everywhere. Keep the reservoir cap on and it will come out slower.
PostPosted: Mon May 02, 2011 8:12 am Up
Yeah I've seen the guide, was just wondering if there was a "trick" to emptying it without getting a face full of coolant. I'm already covered in oil, brake fluid and diesel Laughing
PostPosted: Mon May 02, 2011 8:32 am Up
Keep your mouth shut, make sure the coolant isnt to hot & have a free shower as it drains out Laughing
Try not to swallow any Wink
PostPosted: Mon May 02, 2011 8:45 am Up
Laughing
It's probably never been changed so it will be rusty as hell Laughing
PostPosted: Mon May 02, 2011 8:48 am Up
Mine doesnt have a plug either, could be non genuine maybe?
PostPosted: Mon May 02, 2011 8:52 am Up
Possibly Confused
Looks like its never been changed tho because all the bolts and nuts are mega rusty
PostPosted: Mon May 02, 2011 8:55 am Up
Lee wrote:
Possibly Confused
Random
Maybe it was an optional extra? Laughing
PostPosted: Mon May 02, 2011 8:58 am Up
What? save peugeot 20p? Laughing
