Posted: Sat May 07, 2011 7:30 am |
Hi all,Iv got a 2000 2.0hdi d turbo and was wondering if anyone can shed some light on a problem I have with the oil temperature gauge.
Basically when I turn the ignition on it does a double check(up to top and back down)but then just stays at 0 even after a two hour motorway journey.
It is due an oil change next week,though there is plenty in there.
TIA Lee
Posted: Sat May 07, 2011 7:33 am |
problem with the sensor which senses the oil temp? sounds as if the actual guage itself is working.
Any work you undertake as a result of my posts is done so at your own risk | |
Posted: Sat May 07, 2011 7:36 am |
Sounds like you need to have a look at the oil level / temp probe screwed in to the back of the block.
Its a combined probe on this engine, try giving the connector plug a spray of electrical contact cleaner.
