Online Now [704]:
Visitors: 702
Bots: 2
Today: 161580
Total: 154177911
Forums › The Car › 206 Talk › M.o.t bulb quick question
Forum Index › 206 Talk
eddrj
PostPosted: Sun May 08, 2011 10:24 am Up
M.o.t soon , I have put the blue,rainbow Osram bulbs in indicators at front and back will it pass through mot ok?? Or is it worth swapping normal orange bulbs back in.
Also probably wont make a difference but the handbrake light bulb on dashboard isnt working atall must just be the bulb that wont affect mot either would it ? i could do it myself before mot been like it for ages .
Old car 2000/ 206 2.0 hdi.
PostPosted: Sun May 08, 2011 10:26 am Up
If the indicators flash amber then will be ok.
Don't think the handbrake bulb will fail it. It's not a legal requirement as far as I know.
eddrj
PostPosted: Sun May 08, 2011 10:27 am Up
yeah they flash orange, but no where near as bright as the normal ones when flash orange though
PostPosted: Sun May 08, 2011 10:28 am Up
Osram Pearl bulbs will be fine mine has been 2 MOT's with these in and nothing has been said about them.
I do think you will need to get the Handbrake light sorted tho as it could fail on it.
Dabamash
PostPosted: Sun May 08, 2011 10:29 am Up
Staff - Daba
Mine passed with silvertec bulbs in, so I imagine yours will
what do you mean no where near as bright? Mine are fine and are the same brightness as the normal ones
eddrj
PostPosted: Sun May 08, 2011 10:30 am Up
Really would fail on handbrake light ? o dear ..
ok il sort it quick lol may just be lose bulb il get new one anyway there really cheap and easy , ok good because was thinking about changing bulbs back just for mot if need too.
eddrj
PostPosted: Sun May 08, 2011 10:31 am Up
Mine dont seem to be as bright as normal ones
PostPosted: Sun May 08, 2011 10:32 am Up
As said havent noticed any different really
eddrj
PostPosted: Sun May 08, 2011 10:33 am Up
Ok thanks for the help i best get the handbrake bulb sorted then.
PostPosted: Sun May 08, 2011 10:52 am Up
No requirement for the handbrake bulb to work. It's similar to any other dash light. There is no legal requirement to have the dashboard illuminated at all.
The only requirement is for the ABS warning light (if fitted) to be operational.
Edit. Do you have an aftermarket headunit fitted. Some people disconnect the handbrake switch so that they can watch DVDs while vehicle is moving. Might be worth checking that before changing the bulb.
PostPosted: Sun May 08, 2011 11:11 am Up
They'll be fine. We had 24volt bulbs in a 12volt car so they were mega dim and they still passed
PostPosted: Sun May 08, 2011 11:45 am Up
That bulb is also the LOW BRAKE FLUID warning light, fit a new bulb ASAP! Wink
eddrj
PostPosted: Sun May 08, 2011 12:09 pm Up
yeah true i know , i check it quite regualry for this reason ,
also take it led sidelights will pass as normal ?? they are white slight tint blue as almost all of them are.
PostPosted: Sun May 08, 2011 12:10 pm Up
Just change the bulb in the instrument cluster, its not exaclty hard on a 206 Wink
