Latest: heikkisj
Overall: 17126
Online Now [52]:
Visitors: 51
Today: 2134
Total: 100286113
Forums › The Car › 206 Problems › 206 SW 1.4 Engine Cutting Out
PostPosted: Sun May 29, 2011 10:59 am Up
finners wrote:
erm whats a BSI?
is BSI another name for ECU
no.
they are not the same.
PostPosted: Sun May 29, 2011 11:12 am Up
finners wrote:
erm whats a BSI?
BSI is the Built in Systems Interface which is the software driven computer brain that has overall control of all the cars electrical systems Wink
finners
PostPosted: Mon May 30, 2011 4:48 am Up
MrBSI wrote:
Shut the BSI down safely before touching those connectors.
Is there a set way of shutting down the BSI then? Is it not a case of just disconnecting the battery?
206 5 DOOR ESTATE 1.4i 75 (TU3JP) Manual gearbox 5 - 54 Plate
finners
PostPosted: Mon May 30, 2011 5:07 am Up
I've found it by doing a quick search of the forum Wink
PostPosted: Mon May 30, 2011 6:32 am Up
Nice one, someone that actually bothered to use the search Cool
finners
PostPosted: Mon May 30, 2011 11:26 am Up
Ok so I've disconnected the ECU and cleaned up the connectors with electrical contact cleaner.
All back together so we'll have to see how it goes.
I'll phone the local Peugeot dealer tomorrow to see about an ECU/BSI update.
PostPosted: Mon May 30, 2011 11:31 am Up
Did you find any nasty / crusty silicone grease there?
finners
PostPosted: Mon May 30, 2011 11:33 am Up
Nope it looked pretty clean. I sprayed the connectors just to be sure though.
finners
PostPosted: Wed Jun 01, 2011 10:37 am Up
I've booked the car into a Peugeot garage for them to do a diagnostic test, 30 minutes labour (to fix any probs they might be able to do in the 30 mins) and to update the ECU software.
67 notes. Confused
finners
PostPosted: Thu Jun 02, 2011 10:41 am Up
Well the wife was driving the car again today and had a boat load of problems.
Car is stalling a lot now with the temp gauge going up to 100 and then down to under 70. The engine feels like it is pulling you back all the time.
The engine management light flckers on and off alot also.
Do you think its still an ECU fault guys?
finners
PostPosted: Mon Jun 06, 2011 10:01 am Up
Well the car has been to the Peugeot garage and had a diagnostic test done. It showed only one fault which was a 'Coolant temp sensor fault in multi-function display'.
They also carried out an ECU download and update.
& guess what on the way home it stalled about 4 times. This was when the engine was warm so I am thinking it may be the coolant temp sensor. What yer reckon guys?
To be honest I am not very impressed with Peugeot, you would atleast think the mechanic would have come out for a chat but no leave it to the receptionist.
More than happy to take the 67 quid off me and it felt like "there yer go kid see how you go"..................
PostPosted: Mon Jun 06, 2011 1:03 pm Up
that could be it.
i remember i have seen a similar case before
finners
PostPosted: Tue Jun 07, 2011 4:23 am Up
Yeah I'll take a look at the coolant temp sensor and I might clean the MAF sensor while I'm at it.
finners
PostPosted: Tue Jun 07, 2011 8:01 am Up
Well I cleaned the MAF sensor but to be honest it didnt look that bad. I havent replaced the coolant temp sensor but I did clean the electrical contacts.
Went out for a drive and initially its fine but it seems to cut out when the temp is just above 90C. The engine does not misfire or anything it simply just cuts out.
I am really started to get a bit peeved off with it now. Nobody seems to have a clue as to exactly what it might be and as you can see from my previous posts I have changed quite a few parts.
The only things that I havent renewed is the coolant temp sensor. I see there are a number of other sensors on the car is it worth looking at any of these? I read somewhere there are 2 coolant temp sensors one for the gauge and one for the ECU, is this true?
I also read there are relays at the bottom of the radiator and a travelling/speed sensor.
I am open to all ideas as I dont want to part ex the car just yet Very Happy
finners
PostPosted: Tue Jun 07, 2011 1:19 pm Up
I've fitted a new coolant temp sensor so will see how it goes......
Page 3 of 4
