Posted: Wed Jun 08, 2011 7:23 am |
Guess what its happened again!!!
The car had been running fine for about 30 mins but I parked it in Tesco's today and left it running for a while. It cut out when the temp gauge was at about 95C.
The fan appears to be working fine but I am completely stumped now.
Any advice guys?
| 206 5 DOOR ESTATE 1.4i 75 (TU3JP) Manual gearbox 5 - 54 Plate | |
Posted: Thu Jun 09, 2011 4:01 am |
The car stalled again today and the engine was not that warm so I think I can rule out it being a heat issue. It stalled and then wouldnt start again. It was turning over but just not firing which I suspect may be a fuel issue. I turned off the car for about 20 seconds and it started fine.
The wife was driving behind me and said she could smell fuel when I stalled.
Food for thought I suppose!
Posted: Fri Jan 06, 2012 5:25 pm |
HI, did you ever get to the bottom of this?
My 2001 1.4i GLX used to cut out every now and then but would start straight away with one turn of the key no problem.
The last few weeks it has got worse and it is doing it nearly every day. Always when I'm slowing down for a junction or roundabout etc.
I've been told that it might be the fuel filter depending if it is an external one. Not sure if that is true.
| 2001 206 1.4i GLX
2001 Megane 1.6i Dynamique 16V
2008 207 1.4 HDI
2014 Focus 1.6 TDCI Titanium Nav
2020 Jaguar E-PACE Chequered Flag D150 AWD + 2002 Ford Focus 1.6 Ghia run-a-bout | |
Posted: Fri Jan 06, 2012 5:27 pm |
| LeeUK wrote: |
Might be in for a long wait for a reply, thats the last time finners posted on the forum.
Posted: Sat Jan 07, 2012 2:37 pm |
| LeeUK wrote: |
I've been told that it might be the fuel filter depending if it is an external one. Not sure if that is true. |
No I never go to the bottom of it I'm afraid, sorry.
Posted: Mon Feb 20, 2012 2:30 pm |
Just having similar problems myself. Finners did you end up getting rid of the car?
Your pics have made a good guide for me to try the things you've done
Posted: Mon Feb 20, 2012 4:36 pm |
| Bummers wrote: |
Your pics have made a good guide for me to try the things you've done  |
Yeah I ended up getting rid of the car. I hope you get to the bottom of your problem.
