Latest: heikkisj
Overall: 17126
Online Now [51]:
Visitors: 50
Today: 5272
Total: 100289239
Forums › The Car › 206 Problems › 206 SW 1.4 Engine Cutting Out
finners
PostPosted: Fri May 13, 2011 12:10 pm Up
roberto.f wrote:
Yeah you can just leave them. iirc Super 4's can't be adjusted anyway.
good stuff, cheers Smile
206 5 DOOR ESTATE 1.4i 75 (TU3JP) Manual gearbox 5 - 54 Plate
finners
PostPosted: Sat May 14, 2011 6:50 am Up
Well I have replaced the spark plugs and taken a few pics of the coil pack and plugs.
It does appear to be a Sagem coil pack so I am assuming I should replace this?
PostPosted: Sat May 14, 2011 9:08 am Up
I wouldnt want a Sagem coil pack on my 206 Wink
finners
PostPosted: Sat May 14, 2011 11:50 am Up
MrBSI wrote:
Bouricord OR Electrofil
Match the colour of the connector plug up on your car, it will be either grey or black, they aint interchangeable!
There is also a wiring mod to look for.
There is a supressor fitted to pin 4 of the coil pack connector plug.
Peugeot / Citroen part number 6555 K9
I am scouring eBay for one of these coil packs but to no avail. Can anyone help me out please?
this is a pic of my engine and just to confirm is this the suppressor mod you were talking about?
finners
PostPosted: Sun May 15, 2011 2:59 am Up
I've ordered a new Coil Pack and I only paid £30.00 including postage. Its a Valeo one with the grey plug and the part numbers on it seem to match the ones on the Sagem so we'll see if it does the job. Wink
I'll report back once its fitted.
PostPosted: Sun May 15, 2011 6:16 am Up
That little thing in the picture could very well be the supressor, mine was done under Peugeot warranty & its very well hidden behind the coil pack Laughing
finners
PostPosted: Sun May 15, 2011 12:03 pm Up
I found this after doing a google for the part number you mentioned which looks very similar to the part I have pointed to in the picture.
cgi.ebay.co.uk/Genuine...0678937548
However it does say radio interference suppressor.
PostPosted: Sun May 15, 2011 12:08 pm Up
Its the correct part for the job on the coil pack Wink
PostPosted: Sun May 15, 2011 12:10 pm Up
Someone got ripped of on Ebay, there only £5.29 brand new from any Peugeot / Citroen main dealer Laughing
finners
PostPosted: Tue May 17, 2011 9:24 am Up
New coil pack fitted and the car feels a lot better. Will test it for a few days and see how it goes.
finners
PostPosted: Sun May 29, 2011 9:37 am Up
Well the car conked out again today Crying or Very sad
All in all I have changed the following: -
1. Idle Control Valve
2. Spark plugs (changed to Bosch Super 4)
3. New coil pack
Anyone have any other advice as to what I can check next?
Is it worth looking at some of the sensors?
Is it possibly the ECU?
cheers
PostPosted: Sun May 29, 2011 9:53 am Up
Engine ECU software update at the local Peugeot main dealer might be worth thinking about, while its there get the BSI software updated as well.
Give the engine ecu connectors a good clean with electrical contact cleaner incase there's any nasty silicone grease residue there.
finners
PostPosted: Sun May 29, 2011 10:14 am Up
Any idea how much its costs to get these updates?
& when you say the engine ECU connectors are these the ones that you are talking about?
PostPosted: Sun May 29, 2011 10:34 am Up
Yes, those are the conectors, you might find some silicone grease in there, that all needs cleaning out with electrical contact cleaner.
Shut the BSI down safely before touching those connectors.
Software updates - you need to ask the dealer, might be half hour labour or might be an hour labour.
finners
PostPosted: Sun May 29, 2011 10:41 am Up
erm whats a BSI?
is BSI another name for ECU
Page 2 of 4
