Latest: Mr-Koekwaus
Overall: 17125
Online Now [121]:
Visitors: 120
Today: 31152
Total: 100167969
Forums › The Car › 206 Problems › Overheating problem..
Norvvv
PostPosted: Wed May 11, 2011 10:02 am Up
When in traffic temp just rises and rises, fan kicks in just before 100 but if anything makes the temp go up faster it doesn't work properly! :/ sounds like it's overworking too, don't know how loud the fan should be?
ukskater01
PostPosted: Wed May 11, 2011 11:28 am Up
My fans quite loud but I've had a friend oil the bearings and it's not as bad now, still a bit embarrassing though Smile my fan kicks in when I'm sitting in traffic and the temp gets to just above 90. Think you might need a new thermostat mate, I'm sure someone else has a bit more knowledge on this than me though
BigGreenDave
PostPosted: Wed May 11, 2011 11:31 am Up
i had same problem mate but the fan wasnt kicking in at all. so i went ahead and put my fan on a switch from the relay so now its a manual fan and i have to watch the temp Razz but it still sits at the middle of the temp gauge just keeps it nice and cool Razz
F**k Scene YAWN
perry081064
PostPosted: Wed May 11, 2011 11:41 am Up
probably end up doing this to mine , on testing , i can trip it on if i bridge the relay . . im just too thick to work out how to make it work from a switch.
... any photo's would be great if you ever get the time Wink
206 2.0 HDI
coopskin
PostPosted: Wed May 11, 2011 2:56 pm Up
Trade Rating: +13
yours sounds like the problem i have, the fan sounds like it kicks in but actually doesnt, it attempts to and you can hear it attempt, but shorts out.
what you need is to trace the correct relay, replace it, and replace the wiring that has probably coroded. that should sort it out.
Norvvv
PostPosted: Wed May 11, 2011 3:48 pm Up
Okay cheers mate, the fan doesn't seem to short out though it stays on and makes a loud noise it just doesn't seem to cool the engine the temperature still rises :/
