Latest: Flyin180
Overall: 17116
Online Now [51]:
Visitors: 50
Today: 5630
Total: 95096162
Forums › The Car › 206 Talk › rear beam bearings
rear beam bearings
shell-vt
PostPosted: Thu May 12, 2011 3:10 am Up
Trade Rating: +46
well usual suspect rear beam bearing has play so £££ to spend anyone else had or got this problem, we only found out today as car was back in for lowering and suspention work as its a track car so disapointed.....
york 16,3
ukskater01
PostPosted: Thu May 12, 2011 3:53 am Up
Is it definitely the bearing as I had play in my offside rear wheel, thought it was the bearing but it was the tracking arm and bush I think, have you got noise coming from the rear?
PostPosted: Thu May 12, 2011 5:25 am Up
do a search, there is mant topics + guide for doing the rear bearing
shell-vt
PostPosted: Thu May 12, 2011 7:57 am Up
Trade Rating: +46
Nar cars allready up at manic motors getting new bearing fitted then lowerd . Drivers side had play in it as its a track car it needs doing also thair is x2 diffrent types of bearing sizes. Just a pain really and a cost I could of done without, but its a common thing on frenchies.
york 16,3
shell-vt
PostPosted: Thu May 12, 2011 8:03 am Up
Trade Rating: +46
Ey I'm asking if any other members have had rear beam probs
york 16,3
PostPosted: Thu May 12, 2011 10:33 am Up
normal problem on 206
shell-vt
PostPosted: Thu May 12, 2011 11:41 pm Up
Trade Rating: +46
Didant think the 206 was as bad as 205 309 even saxo but we all learn
york 16,3
PostPosted: Fri May 13, 2011 3:20 am Up
ya, basically is the design problem i think.
they all suffer from rear axle problem. but normally it will be fine if you change the bearing regularly.
shell-vt
PostPosted: Fri May 13, 2011 6:02 am Up
Trade Rating: +46
weak bearings cheaply made
york 16,3
PostPosted: Fri May 13, 2011 1:34 pm Up
don't think so
