Posted: Wed May 18, 2011 6:27 am |
hi all, just a quickie...
working round the "to do list" on the 206 and i thought id post this up here as ive not looked into it yet.
my middle display on the dash doesnt illuminate at all, ive currently got no headunit in but didnt think that matters??
the dash lights are a bit pants aswel, anyone got any upgrades for this??
its a 2000 gti by the way.
thanks in advance spud.
| 2004 GTI 180 - SOLD, 2000 GTI - SOLD, 2002 SW D TURBO - CURRENT | |
Posted: Wed May 18, 2011 6:30 am |
There is a 'how-to' thread on this problem somewhere. It wont be long and someone will post it up for you lol. I think its done by DJ
Posted: Wed May 18, 2011 6:33 am |
Posted: Wed May 18, 2011 6:40 am |
Could just be dimmed a bit too much
Posted: Wed May 18, 2011 8:17 am |
Slap it hard!! No diet it shall be a fault wire
| F**k Scene YAWN
Project GreenMachine: 206info.co.uk/Forums/v...rt=75.html | |
Posted: Wed May 18, 2011 9:51 am |
Non plexed GTI, the PPT 30 display will be shagged
50 / 50 chance its repairable with DJ's How To
If not good luck finding a working 2nd hand one
Posted: Thu May 19, 2011 12:42 am |
haha cheers for the replys guys.... and gals
will flick it out and strip it down to see if there is a loose solder connection other than that ill have to do somthing with the spaceits going to leave lol
ive adjusted the dimmer switch both ways and the brightness only seems to get worse so assume some lamps may be out.... will have a look when ive done the mechanical stuff.
thanks again
Posted: Mon May 23, 2011 12:18 am |
right then.....
took it to bits over the weekend as i also changed my dials (see other problem topic)
no loose connections at all, put back in and the display is working but there doesnt seem to be any back light to the display, the lamps dont illuminte evn when the side lights are on....
is this the normal way for these to die or is there anything else i can do??
thanks in advance
Posted: Mon May 23, 2011 2:39 am |
MrBSI wrote: |
If not good luck finding a working 2nd hand one |
those things are like rocking horse s**t at times
Posted: Mon May 23, 2011 4:27 am |
If I needed one of these for a car i was keeping I would get a new one:
The production problems should have been sorted & it will come with a warranty.
Posted: Mon May 23, 2011 4:46 am |
to be honest i only need the clock so might just get one out of another car and fab a bracket up.
thanks for the input.
Posted: Mon May 23, 2011 9:38 am |
With the PPT_30, is it the liquid crystal in the screens that fail or the circuit board?
Posted: Tue May 24, 2011 12:17 am |
my screen seems to be working but its not bright at all, there doesnt seem to be a back light so going to try and find where the feed should be coming from and replace the lamps in it.... fingers crossed, i dont know what way these things die....... maybe its just because there french??
