Posted: Fri May 13, 2011 11:23 am |
i jus got coilovers put in my car but its too low to get a trolly jack underneath! i need some1 to hold up my arch while i slide the jack in..but im dredin the day i get a flat tyre on my own..so my question im askin is that can u get a special type of jack that would b able 2 get under the sills?
Posted: Fri May 13, 2011 11:26 am |
spike_202 wrote: |
My Powerflow is quite loud but then again it's on ITBs and has a decat. |
Audi Sport  | |
just drive onto blocks of wood easy... i constantly have this problem
i just use the standard boot jack, then put the trolly jack under
Take a block or two of timber to drive up.
the wind up jacks should be no problem or alternatively carry a peice of wood in ure boot and drive onto that
Posted: Fri May 13, 2011 11:32 am |
even the back of my car is that low i need 2 jack up the torson bar 2 get the spare wheel out haha
Posted: Fri May 13, 2011 12:02 pm |
Yeah bricks or blocks or wood for me to.
Posted: Fri May 13, 2011 1:11 pm |
Good old bricks and wood
I used them wind up jacks before I lowered it even more (wouldn't fit under then) but broke two of them :s they seem far too weak ,
Posted: Sat May 14, 2011 3:36 am |
If you cant get under your car to get the spare wheel out
Loose some wieght
Alternativelty take a block of wood round with you
| Team Impossible Possible
Posted: Sat May 14, 2011 3:51 am |
Just got a draper scissor jack for jacking it up high enough to get a normal jack in and it goes under fine and mines nearly on the bumpstops.
You can use the jack in the spare wheel to jack it up first but it's really crap.
Posted: Sat May 14, 2011 3:55 am |
MY standard trolley jack doesn't fit under mine but its not ever lowered :S
