Online Now [1994]:
Visitors: 1993
Today: 130788
Total: 152170823
Forums › The Car › 206 Problems › Error Codes finally read...now what...?
gavstar
PostPosted: Sat May 14, 2011 9:06 am Up
So I managed to borrow a code reader and the readings I got back were...
EGR Row Circuit Malfunction
and
Fuel Rail Pressure Sensor Circuit Malfunction...
Anyone able to give me any pointers on what to do ?
The car was sitting for a while before it was even started up, then the engine management light came on and is currently in limp mode.
Any help much appreciated.
Gav
PostPosted: Sat May 14, 2011 9:33 am Up
what engine.....
gavstar
PostPosted: Sat May 14, 2011 10:01 am Up
oh crap sorry, 2.0 HDi W reg
PostPosted: Sat May 14, 2011 10:12 am Up
could be a few things really:
1) could be a broken EGR solenoid valve
2) fault sensor, fault fuel pump or even fault HP pump.
what code reader do you use?
gavstar
PostPosted: Sat May 14, 2011 10:39 am Up
Magically just managed to sort it out.
The wiring for the fuel pressure sensor was all wet inside, took them apart, cleaned them all up and now the car is no longer in limp mode Smile
It was a sealey fault reader, just need to get it back now to turn the light out Razz
Cheers anyways guys Smile
