Latest: S2cgm
Overall: 17178
Online Now [269]:
Visitors: 268
Today: 16529
Total: 136037942
Forums › The Car › 206 Talk › Cruise control
Cruise control
Go to page Previous  1, 2, 3 ... , 34, 35, 36  Next
imlex
PostPosted: Sat May 19, 2012 7:27 am Up
After activate an general error
What's the problem?
My car: Peugeot 206 1.4 Manual Transmission (2008)
Do not stop half-way
manu_cyb
PostPosted: Tue Nov 13, 2012 5:20 pm Up
Try to change the settings in BSI (select the one without limiter, or the type A which doesn't display info on dashboard).
The workaround to pass the ECU limitation is to use Lexia. Choose Citroen C3, choose your engine type, go to injection - settings and change "cruise control" form "absent" to "present". Same for limiter, if you have the limiter stalk. But the limiter will work only if the acceleration pedal has 5 wires (the one with kickdown).
You can also find relevant info regarding CC here (french, but google translate works nice):
www.planete-206.com/t1...se-206-mux
You will have to create an account and log in in order to be able to access the thread.
Let me know if that helped Wink
2004 1.4 HDI
SinfulSaint
PostPosted: Thu Sep 05, 2013 1:33 am Up
I've done it. 2008, 1.4 8v muxed. Stalk installed and fully functional now.
Got me a CC stalk of the ebay. No limiter on it. Removed the cowling behind the wheel and attached the stalk. Found a guy with a DiagBox and PP2000. He tinkered with it a little, enabled the CC without the limiter functions and we got the same case as shown on the photo above. All dashboard fully lit, but no regular messages.
Solved it by enabling the dashboard info to display CC info which was off by default. This option being buried somewhere in PP2000. Took us another battery negative pole removal, ignition on and off we went.
Non Bene Pro Toto Libertas Venditur Auro
iainlovatt
PostPosted: Thu Sep 05, 2013 3:15 am Up
So you have actually managed to get Cruise Control to work?
I was thinking of giving it ago the other week.
Are you able to give a step by step process of what exactly you did. Very Happy
(My Garage)
SinfulSaint
PostPosted: Thu Sep 05, 2013 4:46 am Up
Yes. Like I sad. CC fully functional with info messages 'CC OFF' on the dashboard.
Speed up/down info and acceleration all works fine. The guy running the PP2000 did most of the work and enabling/disabling the features inside took most of his time.
I'm no expert on PP2000 matter and I can't precisely say what-where-why, but I can try to do my best.
iainlovatt
PostPosted: Thu Sep 05, 2013 4:53 am Up
Brilliant. Smile Very Happy
(My Garage)
SinfulSaint
PostPosted: Thu Sep 05, 2013 5:19 am Up
The only problem we faced was the dashboard error like shown on the photo above. He quickly run thru some of the information options for the display and changed it from absent to present. Took us another key turn to ignition off, removed the positive battery connector and placed it back again. Ignition on, test drive and all works.
BURNOUT
PostPosted: Sun Nov 10, 2013 5:16 am Up
After activating cruise control via pps you need to disconnect the battery and then reconnect it. After you do this, your instrument panel will be OK.
nikolam1001
PostPosted: Wed Apr 16, 2014 3:34 am Up
Did anybody manage to install cruise control on peugeot 206 gti180/RC?
iainlovatt
PostPosted: Wed Apr 16, 2014 6:26 am Up
I have a 2005 gti and i tried all this and more and still coudnt get it to work, Its down to my ECU, !
(My Garage)
nikolam1001
PostPosted: Thu Apr 17, 2014 7:59 am Up
I have same problem, maybe ecu need to update from peugeot...
mattymj
PostPosted: Thu May 01, 2014 1:12 pm Up
I have a stalk for sale if anyone is interested. £35inc p&p My 180s ecu was locked.
mattymj
PostPosted: Tue May 27, 2014 1:25 pm Up
Cruise control link
Anyone with the now how could try this method
wobblycat
PostPosted: Sun Feb 09, 2020 8:01 pm Up
got CC working on a 2006 1.4 HDI.
Having trouble with the limiter - I am getting an error on the speedo display and PP2000 is telling me there's an issue with the accelerator pedal.
I think this is because I don't have the kickback pedal, I just have the normal one.
Has anyone got a kickback pedal part number for the 206?
yeah
nuwan
PostPosted: Fri Apr 30, 2021 7:15 am Up
Hi,
Does anybody can help me on this ? I'm getting invalid value in BSI and download faulty in instrument panel configurations. My ecu (J34P) has two option to enable cruise control.
1. RVV1 - enable cruise control with out speed Limiter
2. RVV2 - enable cruise control with Speed Limiter
Only the 2nd option can be enabled( mark as present). Other one doesn't seems to be change. (no present option at all)
It has 4 wires brake switch, clutch switch and 4 wire acceleration paddle. (doesn't support limit as I read)
Its 2006 xr (VIN VF32AKFWA47460712)
Any idea or clue that helps me to enable cruise control. Thank you.
Page 35 of 36
