Posted: Sun May 15, 2011 12:27 pm |
Just noticed werid air noise coming from coolant expansion tank any ideas , ? anyone else had this ?
Is it air lock or need new cap cause know they have 15psi on them , ive had coolant changed few months back.
| New car 2011 / Thoruim grey , 207 1.4 Vti 16v Sport 95bhp , tinted rear windows.
Old car 2000/ 206 2.0 hdi. | |
Posted: Sun May 15, 2011 12:47 pm |
is vehicle overheating?? or heater not working??
| drive fast !!! live life faster !!! | |
Posted: Sun May 15, 2011 12:51 pm |
goes high in traffic dont think fans working, never overheated though no , heater is working yeah.
Just gone out and its still hissing at me lol like a snake coming from coolant tank notice it when been for a drive then get back look under bonnet and hear it .
Posted: Sun May 15, 2011 12:58 pm |
sounds like back pressuring aka head gasket probably
Posted: Sun May 15, 2011 1:02 pm |
have you bled it by the 2 bleed places ?
but the oil and coolant are fine arent sluggey brown colour thought that was main symton of head gasket and no coolant leak .
I have nothing else wrong just werid air noise .
sounds like its got a fair bit of back pressure.
could be the start of a headgasket failure, it may be worth your while having it checked at a garage to see if gasses are present in the cooling system, also check the coolant for oil in the mixture.
Posted: Sun May 15, 2011 1:03 pm |
Not sure ,my mechanic did it so i duno about the bleed srews
Posted: Sun May 15, 2011 1:07 pm |
get the coolant sniff checked. the coolant and oil dont need to b sludgy to mean a blown headgasket.
Posted: Sun May 15, 2011 1:08 pm |
coolant sniff ?? also thought loss of power is a sign and goes well the same
Posted: Sun May 15, 2011 1:11 pm |
there's 2 bleed places.
one is at the front and there's another thats on the pipes that go to the heater matrix
( next to brake servo , round black plastic thing with a slot for a screw driver )
like perry said they test for gasses in the coolant. with a blue fluid in a tube if it turns bright yellow/green there is a head gasket fault dont have to b down on power ether.
Posted: Sun May 15, 2011 1:12 pm |
eddrj wrote: |
coolant sniff ?? |
garage will put a special mix into a tubey type thing and suck the mixture.
( if it turns dark blue , bend over and pass him the vasaline )
Posted: Sun May 15, 2011 1:13 pm |
sorry my mistake ... green
Posted: Sun May 15, 2011 1:14 pm |
ok there are the 2 bleed places,
what do i do and how much do i turn them i havent got a clue lol soz .
Ok il get my mechnic to take a look at it
