Latest: heikkisj
Overall: 17126
Online Now [51]:
Visitors: 50
Today: 9133
Total: 100318534
Forums › The Car › Request a how-to › how to change the 2.0l gti pre-plexed cam belt
Forum IndexRequest a how-to
gtichris
PostPosted: Fri Jul 08, 2011 3:27 am Reply with quote Up
is there any guides on how to change the cam belt on the 2l gti engine thanks
2.0l GTI 3 door (137) (2000) x reg
PostPosted: Fri Jul 08, 2011 3:29 am Reply with quote Up
In the Haynes manual there is.
JE_180
PostPosted: Fri Jul 08, 2011 3:39 am Reply with quote Up
Aslong as it's the regular GTI the Haynes manual as Chris said Smile
PostPosted: Fri Jul 08, 2011 3:49 am Reply with quote Up
Autodata - there is a slight cost though.
www.autodata-online.co...ngbelt.asp
gtichris
PostPosted: Fri Jul 08, 2011 3:57 am Reply with quote Up
ok cheers guys haynes manual it is then
PostPosted: Fri Jul 08, 2011 5:26 am Reply with quote Up
Haynes manual does the belt change in a 307. It fails to take into account the lack of space for your hands on a 206!
PostPosted: Fri Jul 08, 2011 5:55 am Reply with quote Up
gtichris
PostPosted: Fri Jul 08, 2011 5:17 pm Reply with quote Up
Lee wrote:
thanks will have a look through in morning im too tired to look now so nite all
  Quick Reply
Username:
Message:
Quote the last message
