Online Now [388]:
Visitors: 387
Today: 16459
Total: 156536750
Forums › The Car › 206 Talk › irattic indicaters
irattic indicaters
Forum Index › 206 Talk
leigh_boy
PostPosted: Fri May 20, 2011 1:51 am Up
my indicators did a thing were they just go off when they want, but only did it now and then, but now does it all the time, i see there is a thread in the How to area, so will give it a clean but if not i need to remove it, how does the airbag connector come off? ORANGE connector
i also noticed that my stalks have a lot of movement, now i see there are 2 thumb screws in the back of the stalk holder, how much movement should there be?
any advise given appreciated not taken the steering wheel off before.
*DEAD*206 Gti 138
Toyota Celica T sport 205 BHP
PostPosted: Fri May 20, 2011 1:58 am Up
You tried the new stalks I gave you?
MrrNoName
I believe that if its multiplexed (after 2001?) you will need a new com2000 unit, if its pre-plexed you can just replace the indicator stalk.
sorry I cant really answer your question but if it helps your symptoms are almost certainly that if you have loose stalks Razz
PostPosted: Fri May 20, 2011 2:01 am Up
It's pre plexed. And he stole a new set of stalks from me Razz
MrrNoName
PostPosted: Fri May 20, 2011 2:02 am Up
lol, just fit a new stalk then Razz dont bother messing around with the worn one Smile
leigh_boy
no thats what i want to try.
*DEAD*206 Gti 138
leigh_boy
PostPosted: Fri May 20, 2011 2:03 am Up
pre plexed
*DEAD*206 Gti 138
