Latest: sparrowdclxvi
Overall: 17139
Online Now [316]:
Visitors: 315
Today: 5337
Total: 112689394
Forums › The Car › 206 Problems › Can anyone help?
Can anyone help?
acotton21
PostPosted: Fri May 20, 2011 1:18 pm Up
2 things really;
1. when i turn corners its makes a really loud squeaking noice like a crunch (not a knock like driveshaft) only when driving slowley.
2. i can hear a whistling noice when i drive over 30/40mph
can anyone help?
Thanks Ant
richpowell91
PostPosted: Fri May 20, 2011 1:35 pm Up
Not sure about the second but for the first i would say check your front top suspension strut bearings. Try getting someone to listen to hear where the noise is coming from while you rock the steering back and forth on the spot. Should narrow it down if not the bearings.
acotton21
PostPosted: Fri May 20, 2011 1:51 pm Up
is it an expensive job?
richpowell91
PostPosted: Fri May 20, 2011 1:56 pm Up
The bearing itself should cost about £26 for a genuine peugeot one or £15 for a non genuine. Its just getting to it thats the problem as you have got to strip that corners suspension down to get to it.
leigh_boy
PostPosted: Fri May 20, 2011 2:58 pm Up
could be bottom ball join or top moout, also secound 1 sounds like diff on the gear box but hard to say with out seeing it
*DEAD*206 Gti 138
Toyota Celica T sport 205 BHP
