Online Now [71]:
Visitors: 70
Today: 62543
Total: 117526039
Forums › The Car › 206 Talk › Left/right speakers?
karimali831
PostPosted: Sat May 21, 2011 6:09 am Up
So I bought a pair of speakers for my JVC KD-R301 but they are both setup as left speakers when I tested it with the balancer, there is no output from the speakers when balanced right but output from both speakers will balanced left so they are obviously both left speakers.
I AM REALLY SORRY if this is a STUPID question but how do I make one of the left and other one as right?
206 GTI 180
stevedude
PostPosted: Sat May 21, 2011 6:24 am Up
most stereos have the ability to run 4 speakers 2 front 2 back, maybe someone wired it up wrong so you have only used the left wires from the back and front, instead of the left and right
Happydays
MrrNoName
PostPosted: Sat May 21, 2011 6:50 am Up
as said above, speakers are not "left and right" they are both exactly the same (either can be left and either can be right) car stereo's can run 4 or sometimes even 6 outputs (three for left and three for right) you just have both speakers plugged into left outputs on the back of the headunit Smile its a simple fix
PostPosted: Sat May 21, 2011 7:23 am Up
Your not playing music that is set as mono rather than stereo are you?
I've got that problem with some of the 'acquired' albums I have
MrrNoName
PostPosted: Sat May 21, 2011 7:26 am Up
Lee wrote:
'acquired'
Wink
thats true, try more than one source, try the radio etc
