Posted: Fri May 20, 2011 3:03 pm |
hi well first problem my 206 is having is that it keeeps blowing the 20amp fuse for interior lights, it only started doing this when a live came out the cd player but once i fixed the live problem , it still blows fuses. also if i jump out the car quickly i can lock it and open it with the key fob quite happily but if i leave it a couple mins it wont open with the fob and when i open it with the key the alarm goes off. all these things started happening after the loose live in the cd player but now that thats fixed its still happening . help please
Posted: Fri May 20, 2011 3:11 pm |
what age is the car??
Posted: Fri May 20, 2011 3:13 pm |
its an 05 plate 206 1.6 16v quicksilver
Posted: Sat May 21, 2011 2:51 am |
minimuff wrote: |
hi well first problem my 206 is having is that it keeeps blowing the 20amp fuse for interior lights, it only started doing this when a live came out the cd player but once i fixed the live problem , it still blows fuses. also if i jump out the car quickly i can lock it and open it with the key fob quite happily but if i leave it a couple mins it wont open with the fob and when i open it with the key the alarm goes off. all these things started happening after the loose live in the cd player but now that thats fixed its still happening . help please |
Its MULTIPLEXED
Reboot the BSI unit.
Cross your fingers you havent fried the BSI.
As for the alarm going off when you open the door manually, what else do you expect
Turn the ignition on to shut it up.
Posted: Sat May 21, 2011 4:49 am |
hey thanx for the reply
i herd doing a soft boot on the bsi could end up putting my car off the road , plus since thers no fuse in the interior lights, would that make the soft boot corrupt ?
Posted: Sun May 22, 2011 11:30 am |
bump , any more advice anyone ?
