Posted: Tue Mar 08, 2011 8:41 am |
Posted: Tue Mar 08, 2011 8:44 am |
jealousss! which ones you go for?
Posted: Tue Mar 08, 2011 8:56 am |
re profile on both the inlet is the same one pipe sell
would be nice if i had a 180 inlet to go with them but dont have the money or skill to fit it lol
Posted: Tue Mar 08, 2011 9:52 am |
How much power gain from these?
| 206 GTI, Ram air filter, lowered 35mm front, 50mm rear, Scorpion 3.5" Back box, phase 2 boot strip, m3 rear lights.. Not much more i want to do, just sorting the paint work out! | |
Posted: Tue Mar 08, 2011 10:01 am |
they say 12 but they say 15 from just the inlet so not sure
Posted: Tue Mar 08, 2011 10:02 am |
Posted: Tue Mar 08, 2011 10:05 am |
hope you are planning on changing the followers at the same time aswell as the valve springs and retainers?
i want some of these soo bad but the total cost once putting the valve springs and retainers aswell as the followers and everything else is a hell of a lot of money
Posted: Tue Mar 08, 2011 10:12 am |
usher wrote: |
they say 12 but they say 15 from just the inlet so not sure |
the inlet that you are on about isnt the same, it has a different duration to the reprofiled inlet
Posted: Tue Mar 08, 2011 10:29 am |
With those cams in the link you shouldnt need to change anything other than the cambelt to fit them. They arent aggressive enough to warrent the change.
spike_202 wrote: |
My Powerflow is quite loud but then again it's on ITBs and has a decat. |
Audi Sport | |
Posted: Tue Mar 08, 2011 10:30 am |
damn you piper lol, they didn't give me those decals and lube
Posted: Tue Mar 08, 2011 10:32 am |
get it on the dyno when its done!
Posted: Tue Mar 08, 2011 10:33 am |
usher wrote: |
well, you will have a remap and RR later aren't you?
Posted: Tue Mar 08, 2011 10:42 am |
Howey wrote: |
With those cams in the link you shouldnt need to change anything other than the cambelt to fit them. They arent aggressive enough to warrent the change. |
thats what i was told by piper cheapest option i cant warrent 500 quid on just the cams atm
Seabook wrote: |
damn you piper lol, they didn't give me those decals and lube |
i can send you the stickers if you want em im not using them
i will be getting a remap in a few month so should have a before and after rr result i also have a std rr print out from when i first got the car so will see how much i have gained overall
Posted: Fri Mar 11, 2011 6:21 am |
just got it booked in for fitting
cams
belts
water pump
150 quid i been quoted
Posted: Fri Mar 11, 2011 6:27 am |
thats good shout!
