Posted: Tue May 24, 2011 4:47 am |
Scanning our 2007 TU3A I get 'Throttle position % = 12' roughly, even when it is fully up (not being pressed).
Is this normal because on a 2001 corsa and a 2001 punto they both
say TP%=0 when pedal is not pressed?
Any help would be much appreciated. (even from Mr.BSI )
Posted: Tue May 24, 2011 4:50 am |
V9977 wrote: |
Any help would be appreciated. (even from Mr.BSi ) |
You aint gonna get any help from me
I know NOTHING remember
MrBSI wrote: |
V9977 wrote: |
I know NOTHING remember  |
Never said that.
Cheers anyway.
Anyone else please?
Posted: Tue May 24, 2011 5:13 am |
seems a little odd to me, is it revving higher then normal at idle?
Any work you undertake as a result of my posts is done so at your own risk  | |
Posted: Tue May 24, 2011 5:14 am |
MrrNoName wrote: |
seems a little odd to me, is it revving higher then normal at idle? |
Nope. 750 rpm when warm.
Posted: Thu May 26, 2011 11:39 am |
Bump
Any ideas?
Posted: Thu May 26, 2011 11:44 am |
does it read 0% when fully depressed?
Posted: Thu May 26, 2011 11:52 am |
macj wrote: |
does it read 0% when fully depressed? |
you mean 100%?
I think so, have to re-check.
Posted: Thu May 26, 2011 1:31 pm |
not 100%..... I meant 0% when fully depressed
Posted: Thu May 26, 2011 2:06 pm |
macj wrote: |
not 100%..... I meant 0% when fully depressed |
Hmm..
Me check.
Posted: Fri May 27, 2011 5:26 am |
macj wrote: |
No.
It reads 84% when pressed to the floor (engine off).
11% fully up (engine off).
14% fully up (engine running and warm at 750 rpm idle).
Posted: Fri May 27, 2011 9:11 am |
sounds fine to me.... the values are correct on the throttle position
Posted: Fri May 27, 2011 9:47 am |
Excellent. Thanks.
I thought previous owner might have gone for a re-map.
There seems to be a slight 'jolt' of the engine 1 out of 10 times when
stationary in neutral and then pressing the pedal down even slightly.
Checked the engine mounts and they seem to be OK.
Posted: Fri May 27, 2011 10:50 am |
I cant see any related issues here. I think that you need to check mounts and linkages as you said
Posted: Fri May 27, 2011 11:01 am |
macj wrote: |
I cant see any related issues here. I think that you need to check mounts and linkages as you said |
What are linkages?
