Posted: Sat May 28, 2011 11:05 am |
SORRY if this is a silly question!
I just tried removing door cards but having problems.
how does it remove from the top? Bottom I managed to do... I can see one pin that needs unscrewing only.
I've got 1.1 btw.
Thanks.
Posted: Sat May 28, 2011 11:07 am |
undo 3 torx screw, remove the door handle (one screw), pull out the door opening catch and then pull out the door card
About 9 clips, three torx screws [handle, hinge side, one behind tweeter cover].
If it takes you longer than one minute, you're a retard
Posted: Sat May 28, 2011 11:08 am |
Posted: Sat May 28, 2011 11:10 am |
Ahh thanks very muchs all
