Latest: DanDan17
Overall: 17128
Online Now [124]:
Visitors: 123
Today: 25340
Total: 100545246
Forums › The Car › 206 Problems › Unidentified oil leak
jonnym92
PostPosted: Sun May 29, 2011 12:17 pm Up
I have had an oil leak for about 3 weeks now and came from the sump but now i have been defeated by the problem of where it is comming from as it hasnt stopped. i have changed the oil filter, sump and gasket and rocker cover gasket. All of these are perfectly done and nothing is coming out of any of these. it isnt a massive leak it is only maybe about CD size patch when its been stood there all night. ALso i have realised the car leaks just after it has been running as it drips then but after a short while it stopps dripping :S
Any ideas would be appreciated.
Jonny
jonnym92
PostPosted: Sun May 29, 2011 12:23 pm Up
another note its on the driver side about a foot back from the bumper like where the gearbox would be should it be on that side
Jonny
Antknee
PostPosted: Sun May 29, 2011 12:36 pm Up
I would have thought it would be coming from a really small hole somewhere because when the oil heats up it becomes less viscous and flow more easily as oppose to when it's cold and more viscous and not being able to penetrate. Just a thought, i could be wrong!
jonnym92
PostPosted: Sun May 29, 2011 12:49 pm Up
i was either thinking something like that or some sort of piping that the oil will run through when the engine is on and once its ran out of them after the car has stopped it stopps leaking.
Jonny
PostPosted: Sun May 29, 2011 1:31 pm Up
the engine oil shouldn't run through any pipe
shell-vt
PostPosted: Sun May 29, 2011 1:54 pm Up
Trade Rating: +46
Its a french thing
york 16,3
richpowell91
PostPosted: Sun May 29, 2011 2:06 pm Up
Have you tried degreasing the bottom of the engine, washing it clean then leaving it over night and then looking for the trail of oil the next day? It would help you narrow down where its leaking from.
jonnym92
PostPosted: Sun May 29, 2011 2:21 pm Up
i have cleaned it down a little and it seems to be running down from above the right hand side of the sump but its not clar exactly how far up its leaking from and i haent really had time to take thigsoff and give it a good clean
Jonny
PostPosted: Sun May 29, 2011 2:22 pm Up
right hand side as in offside or nearside?
(right right depends what side you are looking at it Laughing )
jonnym92
PostPosted: Sun May 29, 2011 2:24 pm Up
my bad haha, driver side i mean
Jonny
