Latest: DanDan17
Overall: 17128
Online Now [107]:
Visitors: 106
Today: 27774
Total: 100547672
Forums › The Car › 206 Problems › egr valve
egr valve
yanto
PostPosted: Sun May 29, 2011 1:32 pm Up
The car is a 206 HDI the E,M,L, light was on when I got the car, got the codes read, 2 too many faults to list, was told to try the E,G,R valve, the car is now in limp mode,
The 2 Solenoids that go to the E,G,R valve The second one nearest the driver side, Took the top
Pipe off and connected it to the E,G,R valve, That keeps the valve open.
Took the car for a drive it smoked like hell, did that for about a mile
Connected all back how it should be, the car no longer in limp mode,
And no E,M,L, The car now runs perfect.
YANTO
PostPosted: Mon May 30, 2011 2:20 am Up
I can't even be bothered to read all that because there is no punctuation at all.
gixxerkev
PostPosted: Mon May 30, 2011 2:29 am Up
WTF !! Think my 10 year old could of written that better!!
An Ex '03 1.4 GLX driver, German technology all the way now.
PostPosted: Mon May 30, 2011 2:55 am Up
I lost track after 15miles. Please use punctuation or at least make it readable somehow.
scousemouse
PostPosted: Tue May 31, 2011 11:15 am Up
why slate the poster for his lack of punctuation why not just ignore the post
if you can\'t fix it with a hammer your problem\'s electrical
cosmicdance
PostPosted: Tue May 31, 2011 12:15 pm Up
I deciphered the post very easily so it's perfectly readable. Unless you're an English teacher and log on to the forums to criticise people's English Very Happy
Andy
Andy
scousemouse
PostPosted: Tue May 31, 2011 12:30 pm Up
well said andy .I thought we were here to help not slag off
stevedude
PostPosted: Tue May 31, 2011 2:47 pm Up
some are here to help, but not that many
i didnt have any trouble reading any of that!
Happydays
