Latest: Andyblue64
Overall: 17123
Online Now [31]:
Visitors: 30
Today: 350
Total: 97981577
Forums › The Car › 206 Problems › FML.
FML.
JE_180
PostPosted: Sun Jun 05, 2011 12:20 pm Up
Drove to FCS last night in my 180 with some friends, enjoyed the day today... drove home and my rear engine mount decides to give up and snap on the way, which then snapped the gear linkage cable. Luckily it was only about 10 miles from my house so RAC managed to tow me home Wall Bang
Is this a possible 'home fix' job? Or am I going to have to get it garage repaired?
Also, where can I get some decent engine mounts that aren't soft as s**t and sheer off the car?
Rant over.
Rock Onnnnn..
PostPosted: Sun Jun 05, 2011 12:24 pm Up
don't think you can fix it urself as the rear bush are pressed into the bracket.
contact macj if you want the uprate mount.
JE_180
PostPosted: Sun Jun 05, 2011 12:26 pm Up
Was watching his tracktime earlier Razz What's the going rate for one?
PostPosted: Sun Jun 05, 2011 1:14 pm Up
Or spoox motorsport iirc. Vibra-technics I think they are...
PostPosted: Sun Jun 05, 2011 1:16 pm Up
I can speak to Ed for you John. He's got solid mounts on his 206.
dalton-gti-180
PostPosted: Sun Jun 05, 2011 2:02 pm Up
were was you watching track time lol Very Happy
your defeat now is your victory in the future
PostPosted: Sun Jun 05, 2011 2:18 pm Up
Don't uprate just one mount, they are designed to work together. Fitting original mounts with uprated mounts means the engine can move the uprated mounts more than they want to be moved.
Also don't buy from Spoox when they just sell Vibra Technics mounts with a Spoox label on them.
Anyway, what broke on the rear mount? Is it something an uprated mount would fix? I imagine it isn't.
JE_180
PostPosted: Sun Jun 05, 2011 11:49 pm Up
I was planning on uprating all of them, I just need telling which ones i should buy. Apparently ragging it home from fcs did it but we weren't even driving hard most of the time, just the odd blip at traffic lights on dual carriage ways :/. but it could have been damaged in the crash i had
JE_180
PostPosted: Mon Jun 06, 2011 1:45 am Up
FCS...
