Latest: heikkisj
Overall: 17126
Online Now [54]:
Visitors: 53
Today: 13222
Total: 100191863
Forums › The Car › 206 Problems › Creaking noise front and back.
hotham15
PostPosted: Wed Jun 08, 2011 9:37 am Up
Hi,
Long story short, I slid into a kerb in the snow at Christmas. Bent the sub axle at the rear and snapped the track rod (thankfully I had crap wheels on). The stub axle was replaced + bent break disc at the rear. Front track rod was replaced. Both driver side. I moved to Norway and didn't drive the car for 6months (It has been driven at least once a week). Now I've brought it over hear and found two odd noises, both on the driver side.
Front:
There is a creaking noise coming from the steering. I turn the when and when it gets towards half a turn, the noise starts. It sounds like it is straining. A dull creak.
Back:
There is a low squeaking / creaking (higher pitched than the front) and only noticeable at low speeds. I've read on the forum and there is lots of mentions about top mounts / links.
Car maintenance over here is outlandishly expensive so I'd like to try fix it myself.
Any ideas.
GTi 180 - Black - GP04 *** - Standard + Typhoon, CL5+ Breaks & Front Splitter.
acotton21
PostPosted: Wed Jun 08, 2011 9:38 am Up
mines the same at the front so would like to know also Smile
PostPosted: Wed Jun 08, 2011 9:39 am Up
Front: Probably the droplinks/anti-roll bar links.
Back: Rear axle (possibly)
hotham15
PostPosted: Wed Jun 08, 2011 10:09 am Up
How can you check if it is droplinks?
What might be up with the axel? Could it be a shock absorber... kinda sound like it make the noise when the suspension compresses (arb)
skard
PostPosted: Wed Jun 08, 2011 10:12 am Up
have you checked the ARB bushes on the front?
hotham15
PostPosted: Wed Jun 08, 2011 10:16 am Up
No.. Just check for sign of wear? Are they visible?
skard
PostPosted: Wed Jun 08, 2011 10:25 am Up
i have a similar problem on my golf and will be fixing it soon. it's more noticeable on a warm day as the bush has dried out and it makes an awful creaking at low rolling speed. in my case i got down the side of the car while a mate turned the wheel and i could pinpoint the noise to the bush.
yeh you could give them a visual check for cracks etc.
just out of interest, whereabouts in norway do you live?
PostPosted: Wed Jun 08, 2011 10:31 am Up
That be from having sex in the car bud
Go slower next time
hotham15
PostPosted: Wed Jun 08, 2011 11:19 am Up
I'll give it a try. Thanks. I'm in Stavanger
skard
PostPosted: Wed Jun 08, 2011 12:06 pm Up
i've been there many a time, nice place on a sunny day!
hotham15
PostPosted: Wed Jun 08, 2011 12:16 pm Up
True story... shame its always raining Wink
skard
PostPosted: Wed Jun 08, 2011 12:52 pm Up
you're right there!
i did however spend two weeks there on standby in 2008 and it was warmer than the med. 30-35c every day! i had no choice but to drink beer to cool down.
hotham15
PostPosted: Wed Jun 08, 2011 1:03 pm Up
Do you know anywhere that stocks parts for the Gti 180 and is willing to post over?
PostPosted: Wed Jun 08, 2011 1:12 pm Up
If the front creaks when steering it suggests problems with the ball joint or top mount bearings. Drop links don't move very much and so tend to only become a problem when riding over bumps.
