Posted: Mon Jun 06, 2011 8:30 am |
Hi all
I've got a pre-plex 2.0 HDi, and my speedo is shot.
I know there are the 1 plug and 2 plug variants, and I know there are the low spec and high spec variants, but do they vary between engine types? I.e Would a petrol set of dials fit mine?
Cheers
| 2000 206 2.0 HDi China Blue
1997 Jaguar XJ6 3.2 Sapphire Blue | |
Posted: Mon Jun 06, 2011 9:02 am |
I do not think petrol ones fit iirc
Posted: Mon Jun 06, 2011 9:12 am |
Bugger.
Posted: Mon Jun 06, 2011 9:20 am |
also remember if petrol ones did fit, they would go right round to like 7/8k rpm, where as a diesel doesnt go that high
Posted: Mon Jun 06, 2011 10:02 am |
should have a part number on the back , and you will also see if they are 1 or 2 plug.
.. just pull the cowling towards you, then its one torx screw to remove.
there's also a code just under the speedo side at the front, but im not sure if this is relevent.
iirc there are 2 variants of the pre-plex type , exp important if fitting lockwood dials.
if you can take a pic ill compare with mine
