Online Now [63]:
Visitors: 62
Today: 16526
Total: 116558982
Forums › The Car › 206 Problems › Front pad anit-rattle spring location?
craggles
PostPosted: Tue Jun 07, 2011 8:06 am Up
Hey everyone,just a quick question,i serviced the mrs 206 the other day and decided to copper grease up the front brake pads/clean etc and a genral check.
Anyway about 2 year ago it had pads and discs fitted by a local garage but what ive noticed is on the driver side there is a rattle spring on the top and bottom of the facing outside pad only,which i though was normal,but on the passenger side there is a single rattle spring fitted to both inner/outer pads at the bottom.
So which side is correct?id of though by the looks at it 2 mechanics have done a side each,only asking as the driverside is squealing.
1.4lx 206
