Posted: Sat Jan 18, 2014 6:36 am |
i need that connector marked in yellow to install my new headlights and also need the wires that go to the bulbs.
but how do you remove that connector?
i took out the plastic'pin'and found out i can almost push the conector inside the headlight but there is no way you can remove it.
it looks like the connector is one piece and i think somewhere on this forum i found a pic of that thing also in one piece.
Posted: Sat Jan 18, 2014 11:56 am |
Well as far as I know,this plug can't be removed ,what is the problem,going from Phase 1 to Phase 2 headlights?
Posted: Sat Jan 18, 2014 1:09 pm |
i bought fake morettes,want to use the wires and connector from the Original lights on the morette's and then connect it to the Original wires.
Posted: Sat Jan 18, 2014 1:21 pm |
pull hard with pliers. Removed one couple days back!
Posted: Sat Jan 18, 2014 1:33 pm |
are you serious?
and that rubber under the connector..that wont go through
Posted: Sat Jan 18, 2014 2:29 pm |
I have some H4 to H7 Adapters if you want to avoid pulling it out? £5 posted.
Shameless sales post.
| Cherry Red 206 1.1 99'
Wanted List;
Crystal Headlights.
PM Me if you are selling! | |
