Latest: DanDan17
Overall: 17128
Online Now [263]:
Visitors: 262
Today: 24545
Total: 100585218
Forums › The Car › 206 Problems › Inaccurate Speedo
Inaccurate Speedo
Silvery206
PostPosted: Mon Jun 06, 2011 3:44 am Up
Hi all,
Basically my speedo is showing inaccurate readings. Sometimes 10 when im doing 70 etc and it seems like the needle is jerking.
I have not tried anything as of yet and wanted your advice.
Its a 206 1.4 Y reg.
Silvery 206
JE_180
PostPosted: Mon Jun 06, 2011 3:46 am Up
Take it to a garage lol, that sounds dodgy as hell
MrZiggerz
PostPosted: Mon Jun 06, 2011 3:49 am Up
Try cleaning it Smile
Silvery206
PostPosted: Mon Jun 06, 2011 3:50 am Up
How do i get it open?
Silvery 206
MrZiggerz
PostPosted: Mon Jun 06, 2011 3:52 am Up
www.206info.co.uk/Foru...=9579.html
Try cleaning the plugs at the back first, before opening it.
Silvery206
PostPosted: Mon Jun 06, 2011 3:58 am Up
Cheers mate ill give the plugs a clean first.
Silvery 206
PostPosted: Mon Jun 06, 2011 4:01 am Up
Could be the control pinion on the gearbox unit. If the teeth have stripped or worn on this, then it doesn't spin at the correct speed in relation to the gearbox tachometer screw.
I've had one of these go before on another car and the speedo fluctuated that much, some times I could be at a crawl and it would shoot to 140mph, other times I could be doing a reasonable speed and the speedo would hardly show a reading..
Check the wiring to the sender unit on the gearbox, it may have got wet or take the unit out completely and give it a clean and a check over. It should only be held in with one bolt, bit of a wiggle and twist and should come out fairly easily.
Out of interest, is your gearbox oil level ok? If it is low, it may have caused the wearing of the gear.
spud_owen
PostPosted: Mon Jun 06, 2011 6:35 am Up
mine does this tempermentally as well, if you stop and turn the key on, off, on, off etc the needle will eventually go back to zero, itll then be fine for months on end!
Honda Accord cdti....205GTI
LACEY AND OWEN ARCHITECTURAL SERVICES
www.laceyandowen.co.uk
Silvery206
PostPosted: Mon Jun 06, 2011 10:03 am Up
Taken speedo out and took clips of both wires off and then put it back in. Speedo problem still there and mileage is now blank: :S
Silvery 206
Silvery206
PostPosted: Wed Jun 08, 2011 9:19 am Up
Changed the sensor no luck at all. Sad
Going to see if I can source a Speedo and see that
Silvery 206
