Online Now [238]:
Visitors: 237
Today: 87975
Total: 143396867
Forums › The Car › 206 Problems › Remote central locking
Moza
PostPosted: Thu Jun 16, 2011 12:48 pm Up
Hi all im new to the site and will be staying Honest !!!! Ive always been a 306 D Turbo guy but have now moved onto a 206 HDI TURBO SPORT as a daily runner. It came with a few probs which are all done now apart from one, the remote central locking. The key works the doors ok and engaged the alarm and of course runs the car lol. The remote part isnt doing anything and its got a new battery.
I found an online guide to programming but it didnt work, I got a new keyfob and swapped the chip with mine then followed the online guide again and still nothing.
This is the type of key that came with the car
cgi.ebay.co.uk/PEUGEOT...45fb218342
any help with programming would be great or info of what to do (garage work) would be great.
HDI TURBO
PostPosted: Thu Jun 16, 2011 12:53 pm Up
That WONT work, you cannot code a new / replacement remote keyfob to a 206 without diagnostic equipment.
Get your original keyfob, put the chip back in it, make sure the battery is ok, start the engine then press & hold the unlock button for 10 seconds to resync it.
Moza
PostPosted: Thu Jun 16, 2011 12:54 pm Up
Thank you I will go out now and try it
HDI TURBO
Moza
PostPosted: Thu Jun 16, 2011 1:05 pm Up
Ok I tried that 3 times to be sure and still nothing, ive been thinking this fob may not be the original for the car or it may be faulty. Can I take it anywhere to have the fob tested to see if its sending a signal ??? Then the next step is diagnostic recode.
HDI TURBO
PostPosted: Thu Jun 16, 2011 1:09 pm Up
Id try rebooting the BSI unit first.
there's MANY Peugeot fobs that look exactly the same from the outside BUT the internals are different & not interchangeable.
There are 2 types of these multiplexed remote fobs for the 206 for example.
It is a good possibilty that it isnt the original remote fob.
it's needs reprogramming useing PPS2000,and then sync. it Smile
Moza
PostPosted: Thu Jun 16, 2011 1:11 pm Up
Hi thanks for the info, is this a Dealer job ???
HDI TURBO
PostPosted: Thu Jun 16, 2011 1:14 pm Up
Ask Lee on here, see if he gonna be passing your area anytime soon.
Moza
PostPosted: Thu Jun 16, 2011 1:19 pm Up
Thanks I will look for him now
Wink
HDI TURBO
PostPosted: Thu Jun 16, 2011 1:38 pm Up
What He Said
mrbadjah
PostPosted: Thu Jun 30, 2011 3:49 pm Up
try checking the fuse box inside the car or under the bonnet similer problem with mine took the rac an hour to find the probably
quicksilver
mrbadjah
PostPosted: Thu Jun 30, 2011 3:51 pm Up
and 80 quid for a home start
quicksilver
