Posted: Wed Jun 08, 2011 7:27 am |
as some know my gti is a write off and i am looking for a new car, now i have seen a GT for sale localy for 1150 done 75k
has 3 problems
1. central locking doesnt always work but does every time on the key
2.radio display does not work
3. has lexus lights
so my question is is the gt exactly the same as the gti wirieng wise and parts wise?
as my plan would be,
1. not sure how to fix if worse came, change ecu, bsi , locks and key transpder from my gti
2. juct swap it over from the gti if its comptable
3. swap with my original lights from gti
| *DEAD*206 Gti 138
Toyota Celica T sport 205 BHP | |
Posted: Wed Jun 08, 2011 7:37 am |
1. Yes
2. Check fuses & bulbs or swap for another PPT30
3. Yes, straight swap.
You rebuilt that engine you had from me yet?
leigh_boy wrote: |
3. has lexus lights |
| Tivoli LX 1.1
Black GTI 180
White VXR Burg | |
Posted: Wed Jun 08, 2011 7:42 am |
CD-530d wrote: |
1. Yes
You rebuilt that engine you had from me yet? |
not yet got 3 other projects on the go lol
fiesta mk4 i bought for £80
and a rover 218 vvc i got given
is everything from my gti transferable to the GT ?
is the gt pre plex ?
| *DEAD*206 Gti 138
Posted: Wed Jun 08, 2011 7:45 am |
As long as they are both preplexed then yes pretty much may be the odd thing that won't though.
Posted: Wed Jun 08, 2011 7:46 am |
leigh_boy wrote: |
CD-530d wrote: |
1. Yes
is the gt pre plex ? |
Yes it should all swap over bar the mirrors.
Posted: Wed Jun 08, 2011 8:07 am |
leigh_boy wrote: |
has 3 problems
1. central locking doesnt always work but does every time on the key Flat battery in key more than likely
2.radio display does not workRadio display? nackered radio then
3. has lexus lights Some chav will buy them on eBay
so my question is is the gt exactly the same as the gti wirieng wise and parts wise? Yes
1. not sure how to fix if worse came, change ecu, bsi , locks and key transpder from my gti Why do you need to do that?
2. juct swap it over from the gti if its comptable Yes
3. swap with my original lights from gti Yes |
Posted: Wed Jun 08, 2011 9:43 am |
nice one, cheers lads
as for the cetral locking problem, the guy said there is 2 keys so i presume it does it with both surly not 2 flat batteries?
does any 1 know how to fold the mirrors in so i can test it?
| *DEAD*206 Gti 138
Posted: Wed Jun 08, 2011 9:45 am |
There is a button on the GT by the mirror adjustment.
Posted: Wed Jun 08, 2011 10:00 am |
Non-plexed can't have two hf remotes. Only one and a valet key
Posted: Wed Jun 08, 2011 10:49 am |
Lee wrote: |
Non-plexed can't have two hf remotes. Only one and a valet key |
What do you mean hf remotes? as in the remote ones?
If so why cant the pre plexed have two?
Posted: Wed Jun 08, 2011 10:54 am |
Yeah remotes.
Because the BSI only allows 1
Posted: Wed Jun 08, 2011 11:06 am |
Lee wrote: |
Eh? Two keys like this? Mine has two.
Posted: Wed Jun 08, 2011 11:08 am |
You've broken my screen
Posted: Wed Jun 08, 2011 11:15 am |
hmm, so a bit of a debate over this.
edward, is yours pre plex? and does both your keys work the cetral locking from the fob?
| *DEAD*206 Gti 138
