Latest: Flyin180
Overall: 17116
Online Now [20]:
Visitors: 19
Today: 9133
Total: 94988652
Forums › The Car › 206 Talk › Manifold Heatwrap/paint
Andrew
PostPosted: Sat Jun 11, 2011 2:32 pm Up
I've been reading about manifold heat wrap and paint to stop heatsoak affecting the rest of the engine bay, keeping everything else cooler
Real world positives? Negatives? Surely it would help fuel economy a little bit??
My 206 thread
www.detailedbyandrew.com
PostPosted: Sat Jun 11, 2011 2:42 pm Up
cool it do very good heat wrap and Techline do very good manifold coating.
if it make engine bay cooler, it will make mpg worse.
the only downside is it will decrease the life of the manifold.
Andrew
PostPosted: Sat Jun 11, 2011 2:51 pm Up
I see, my manifold clanks as it cools down so I wouldn't imagine this would do any favours, I know its normal but I wouldn't want to make it any worse
What about the manifold heatshield, if that was coated would it work to the same effect?
My 206 thread
orangeGTI
PostPosted: Sat Jun 11, 2011 3:37 pm Up
i had may manifold and down pipe heat wrapped on my old car. it was a stainless mani and down pipe but it was good stuff. never noticed a difference in mpg on it . its also better for the engine to take in cold air rather than warm
For vinyl sticker please look at www.206info.co.uk/Foru...30851.html
Or PM me.
Andrew
PostPosted: Sat Jun 11, 2011 4:04 pm Up
Mine are only standard so I imagine they wouldn't last as long when heat wrapped?
My 206 thread
vintageoriginal
PostPosted: Sun Jun 12, 2011 3:07 am Up
This is wrong.
Quiksilver: 1.6 16v Engine Conversion.
Seb
PostPosted: Sun Jun 12, 2011 3:14 am Up
Staff - Seb
Not true, it'll overfuel when you start it up, but that's related to engine temperature not ambient temperature.
Cooler engine bay and intake temp will actually increase mpg in theory. In practice it would probably be the same.
However, wrapping exhausts/manifolds is a great idea. It protects other components from heat and degradation and improves flow inside the exhaust.
usher
PostPosted: Sun Jun 12, 2011 4:11 am Up
i have mine wrapped and it dropped engine bay temps noticably, supposed to improve performance but small effect, i wuold recomend it for the sake of a few notes
but on a gti wrap it first and while wrapping soak the heatwrap in water as when it dries it will tighten little tip i got after having mine fitted, also gloves help
current bam project insta
project thread WIP
garage
FAQ
206 gti firedance
PostPosted: Sun Jun 12, 2011 4:21 am Up
weire because i normally see worse mpg in winter than in summer Laughing
so i always asumme cold intake air=worse mpg Laughing
