Latest: Andyblue64
Overall: 17123
Online Now [288]:
Visitors: 287
Today: 9948
Total: 97957315
Forums › The Car › 206 Problems › tyres r f****d
tyres r f****d
20619d
PostPosted: Mon Jun 13, 2011 1:29 pm Up
right my front tyres where buggered then replaced them then front front spring snaped so put gti 180 springs on. then few months had replace front tyres. got the car lowered and few months again it has worn the inside rite out and outside more or less fine. if got tracking dne will that sort it? please help as don't wnt wear tyres out all time
PostPosted: Mon Jun 13, 2011 1:31 pm Up
Tracking should always be checked when you make/change parts on the suspension set up.
If you don't want to wear out the inside of your tyres, then don't lower the car or get smaller wheels.
too much -ve camber, so that means is too low
20619d
PostPosted: Mon Jun 13, 2011 1:40 pm Up
even when standard springs where on it did it and only got 14s on it
PostPosted: Mon Jun 13, 2011 1:45 pm Up
Well its either not tracked or something is faulty.
20619d
PostPosted: Mon Jun 13, 2011 1:55 pm Up
so get it tracked then c if does it?
PostPosted: Mon Jun 13, 2011 1:59 pm Up
Might as well, only costs about £20
20619d
PostPosted: Mon Jun 13, 2011 2:04 pm Up
ok thanks. backs fine but front not
PostPosted: Mon Jun 13, 2011 2:08 pm Up
did the car pull to either side when you are driving around?
20619d
PostPosted: Mon Jun 13, 2011 2:10 pm Up
pulls to one side abit. but one tyre worn more then the other
KyleHaich
PostPosted: Mon Jun 13, 2011 3:13 pm Up
Same thing happened to mine, went and got my tracking done and the guy said it's due to having 17" alloys on when the car was designed to fit 14's, didn't take much notice though as most people on here have 17's Laughing
New - Pearl Blue Golf Mk4 Match 1.4
Old - Silver 206 LX 1.1
20619d
PostPosted: Mon Jun 13, 2011 3:32 pm Up
i have 14s and it killing my tyres no matter wot sus i have on
