Latest: DanDan17
Overall: 17128
Online Now [131]:
Visitors: 130
Today: 35786
Total: 100596457
Forums › The Car › 206 Problems › Aux belt tensioner
Aux belt tensioner
Taff!
PostPosted: Mon Jun 06, 2011 10:28 am Up
Need to replace mine but found out it costs about £90 (best price). Can you just replace the wheel and bearing without having to replace the mechanism if so where from?
Thanks in advance
206 1.6 Quiksilver
-Dave-
PostPosted: Mon Jun 06, 2011 11:53 am Up
Trade Rating: +36
All that messing about you may as well just do the tensioner. If you own a Pug replacing thing's like that is a regular thing that will happen a lot so moaning about £90 mean's you own the wrong car. Also I wouldn't fluff about with it because I have been told if the tensioner belt snaps it could flick across and take out the timing belt which believe is a lot more than 90 note's.
Ex 206 Owner.
Taff!
PostPosted: Mon Jun 06, 2011 12:30 pm Up
If they're press fit bearings and that's all that's needed then it would only be about £3 to replace but I can't be a**ed with that faff hence looking at about 15 for a wheel and bearing (not sure if I'm looking at right thing hence the query). If a component is ok and just needs a part replacing then there should be no issue with replacing parts provisig it doesn't compromise the part itself. Peugeots are ridiculous for part prices-wanted a seat stop the other day and would have had to buy most of the seat @ £160! I don't want to spend a fortune on what is a budget car especially as I'm getting rid of it as soon as possible
206 1.6 Quiksilver
Taff!
PostPosted: Wed Jun 15, 2011 4:17 am Up
Sorted it all out. garage managed to get me one for £50 and it's running like a dream again
206 1.6 Quiksilver
