Posted: Tue Jun 14, 2011 11:22 am |
I was just wondering if there are any guides on here to changing the battery on a gti 180?
The garages want £90 so i think i'm going to buy one and do it myself.
Posted: Tue Jun 14, 2011 11:32 am |
they want90 pound just to change a battery? or is that including the battery its pretty self explanatory there are 2 terminals undo them n lift them off the battery n there maybe also be another bolt holding the battery into place
Posted: Tue Jun 14, 2011 11:34 am |
| benb wrote: |
| they want90 pound just to change a battery? or is that including the battery its pretty self explanatory there are 2 terminals undo them n lift them off the battery n there maybe also be another bolt holding the battery into place |
A GTI 180 is MULTIPLEXED.
The BSI must be shut down / booted up in the correct way else your risking having to bend over & Vaseline treament from the local Peugeot main dealer
Posted: Tue Jun 14, 2011 11:35 am |
90 inc the battery. yeah i thought that would be it, just wanted to check though.
Posted: Tue Jun 14, 2011 11:36 am |
| MrBSI wrote: |
| benb wrote: |
The BSI must be shut down / booted up in the correct way else your risking having to bend over & Vaseline treament from the local Peugeot main dealer  |
B*lls
battery is 35-40 quid! buy it from uni part and do it yourself!!
Posted: Tue Jun 14, 2011 11:38 am |
| liam180 wrote: |
| MrBSI wrote: |
| benb wrote: |
B*lls  |
If you tried using the SEARCH function on the forum you would find the correct info on how to shut down / boot up the BSI safely so you can change your battery.
Posted: Tue Jun 14, 2011 11:39 am |
bosch S5 ftw
The BSI must be shut down / booted up in the correct way else your risking having to bend over & Vaseline treament from the local Peugeot main dealer :wink:[/quote]
BSI - is that like the ECU???? Never heard it before?
Posted: Tue Jun 14, 2011 11:43 am |
| liam180 wrote: |
BSI - is that like the ECU???? Never heard it before?[/quote]
Controls the internal electronics. Its the cabins motherboard. Search it mate, I've done a whole thread explaining it
Posted: Tue Jun 14, 2011 11:47 am |
| MrBSI wrote: |
| benb wrote: |
I changed mine a few months ago to a bosch battery and just took the terminals off, didn't shut the BSI down and mines fine, i discount my battery all the time and it's fine everytime
It's literary a 5min job
| Moonstone blue 206 1.4look
pro race 1.2 White
Morettes
GTI wings
TEAM: Carbon Fibre
TEAM: I'm a greedy jelly fiend! | |
Think i may have just read it funnily enough, cheers Lee
Posted: Tue Jun 14, 2011 11:48 am |
| Mrs_Howey wrote: |
| MrBSI wrote: |
| benb wrote: |
It's literary a 5min job  |
I was just about to say the same thing GG, mine was off when having the cam belt done and it was just off with the terminals and nothing happened apart from retuning the radio.
Posted: Tue Jun 14, 2011 11:49 am |
I shall laugh in your faces if/when it goes pop
| The Cars:
Peugeot 206 1.6 HDi GTi '06 Plate - O/H's Car | |
Posted: Tue Jun 14, 2011 11:52 am |
| Ste206 wrote: |
I shall laugh in your faces if/when it goes pop  |
Any we shall only have ourselves to blame
I jump started mine alot as well, which your not meant to do
pro race 1.2 White
Morettes
GTI wings
TEAM: Carbon Fibre
