Latest: Andyblue64
Overall: 17123
Online Now [413]:
Visitors: 412
Today: 81237
Total: 98592565
Forums › The Car › Photoshoot Gallery › New Wheels and suspension
stickman
PostPosted: Sun May 01, 2011 3:26 pm Up
after getting 16" OZ Superturismo GT alloys back in december only now have i gotten around to doing it along with lowering the car 35mm
the pics are a bit pants but ill get some better ones tomorrow when i take the car for a wash.
03 China Blue Dturbo
PostPosted: Sun May 01, 2011 3:33 pm Up
Needs to go just a little bit lower in my opinion.
fmonkey
PostPosted: Sun May 01, 2011 3:36 pm Up
Alot lower
Just on here to help with problems with car
Lewis
PostPosted: Sun May 01, 2011 3:41 pm Up
back looks nice, front needs taking down a bit...
Tivoli LX 1.1
Black GTI 180
White VXR Burg
stickman
PostPosted: Sun May 01, 2011 4:12 pm Up
but its lowered 35mm at the back same as the front, i thought that was fine? ill need to drop it another 10mm?
PostPosted: Sun May 01, 2011 4:19 pm Up
That back end is down more than 35mm.
Lecktorious
PostPosted: Sun May 01, 2011 4:27 pm Up
Trade Rating: +59
+ 1.
'98 Nile Blue 306 GTi 6
stickman
PostPosted: Sun May 01, 2011 4:42 pm Up
well i got 35mm lowering springs on the front, what should i drop the front by?
PostPosted: Sun May 01, 2011 4:44 pm Up
Don't forget they need to settle...
stickman
PostPosted: Mon May 02, 2011 2:42 am Up
the front isnt going to drop much more when the shocks have settled?
Tezza
PostPosted: Wed May 11, 2011 3:54 pm Up
Thats what i thought!
1.4hdi!
stickman
PostPosted: Thu May 26, 2011 11:29 am Up
a newer pic.
so what should i do about the front? get new springs or higher the back a bit?
Shortstuff
PostPosted: Thu May 26, 2011 2:38 pm Up
I think its a good height.
I think the back is perfect, Im getting my 180 lowered 30 on the back and 45 on the front.
They handle better with the nose down stance so maybe lower the front some more?
Cya!
PostPosted: Thu May 26, 2011 4:15 pm Up
If you are going to change anything lower the front more don't touch the back.
jedi5000
PostPosted: Sun Jun 05, 2011 10:30 am Up
what alloys are those?
k mitchell
