Posted: Fri Jun 17, 2011 12:49 pm |
I am thinking of upgrading my front bumper to a sports one, It has non sports at the moment... How do you get the fog lights to work? Is a 1999 so preplexed?
Cheers
Posted: Fri Jun 17, 2011 1:04 pm |
I think you would be able to get them working with a switch in the cabin but you will need two relays aswell, pm lee, he answered this on another thread before
| You never really learn to swear until you learn to drive | |
Posted: Fri Jun 17, 2011 2:10 pm |
with pre-plex there is an actual retrofit kit from pug you can buy (often goes cheap on ebay) and is the way to go if you want to keep it OEM.
otherwise, run it off a switch in the cabin as mentioned. if you search you'll see lots of threads with info on this.
| Former owner of a 1.4 HDi for six years | |
Posted: Fri Jun 17, 2011 2:42 pm |
skard wrote: |
otherwise, run it off a switch in the cabin as mentioned. if you search you'll see lots of threads with info on this. | 7
Ill have a look Thanks bro
Posted: Fri Jun 17, 2011 4:33 pm |
get one of these clicky
easy to wire in!! this is how i did mine!
Posted: Sat Jun 18, 2011 12:28 am |
iainlovatt wrote: |
easy to wire in!! this is how i did mine!  |
Thanks!
Posted: Sat Jun 18, 2011 1:20 am |
xspongerx wrote: |
iainlovatt wrote: |
Thanks!  |
No probably, need any help let me know!
Posted: Sat Jun 18, 2011 1:58 am |
ukskater01 wrote: |
I think you would be able to get them working with a switch in the cabin but you will need two relays aswell, pm lee, he answered this on another thread before |
Why would two relays be needed? 1 should be enough to operate both fog lights. I used to run 4 cibie oscars off 1 relay.
