Latest: heikkisj
Overall: 17126
Online Now [92]:
Visitors: 91
Today: 10921
Total: 100189571
Forums › The Car › 206 Problems › front bearings and lower arms
scotty79
PostPosted: Thu Jun 16, 2011 3:12 am Up
I'm needing to get this done and have been quoted around £250 all in, does this sound about right and is it just for one side or would both be done, was told would take about 2 and a half hours but got 1 wishbone done before and didn't take long at all so wasn't sure if that quote was for 1 side or both, thanks
PostPosted: Thu Jun 16, 2011 3:13 am Up
Probs for both
PostPosted: Thu Jun 16, 2011 5:24 am Up
Doesn't sound much if they are doing both wishbones and front bearings.
PostPosted: Thu Jun 16, 2011 5:36 am Up
i would say is one side.
or they just use rubbish parts.
scotty79
PostPosted: Thu Jun 16, 2011 5:45 am Up
I just assumed he'd be doin both bearings at least, wasn't sure though so just thought I'd ask on here for a bit of advice
PostPosted: Thu Jun 16, 2011 5:56 am Up
Do both bearings need changing?
scotty79
PostPosted: Thu Jun 16, 2011 6:07 am Up
don't think so, I just thought things like that were done in pairs or best done in pairs anyway
he's doing 1 bearing and the 2 wishbones
ian89
PostPosted: Fri Jun 17, 2011 12:27 pm Up
i just got my bearings done went to the scrapyard and just replaced the full hub
PostPosted: Fri Jun 17, 2011 12:57 pm Up
Nice.
