Online Now [75]:
Visitors: 74
Today: 72259
Total: 140178946
Forums › The Car › Request a how-to › How to remove rear door cards?
Forum IndexRequest a how-to
acotton21
PostPosted: Thu Jun 16, 2011 3:48 am Reply with quote Up
Sorry if there's a thread already, got some half leather interior and wasnt sure how to get the rear door cards out because of the seat belts.
PostPosted: Thu Jun 16, 2011 3:56 am Reply with quote Up
Angle grinder.
Seriously, 3 or 5 door?
acotton21
PostPosted: Thu Jun 16, 2011 3:57 am Reply with quote Up
3 door
iainlovatt
PostPosted: Thu Jun 16, 2011 4:00 am Reply with quote Up
open back window! remove seal from the ducts,
remove seat belt bolt in the back,
remove the bolt that holds the front seat belt (the one in the foot wells)
Think thats it!
been years since i did it! Smile
(My Garage)
Antknee
PostPosted: Thu Jun 16, 2011 4:02 am Reply with quote Up
pull off the front seat belt adjuster thing that move the bracket thing up and down, undo the big bolt behind it
undo the bracket on the floor and slide the belt off it
take out the back seats (or just bottom), remove the cap from the bolt holding the bottom of the back rear seat belt on and remove the bolt so the belt should be free apart from the top
i think there might be a couple of smaller screws dotted about too
pull up the window seal so it releases the top of the card
now just pull it like you did the front and it should unclip
that should be about right but it was a while ago when i last done it
PostPosted: Thu Jun 16, 2011 4:03 am Reply with quote Up
Firstly have to remove the front seat bellts.
Pop the cover off where it slides along the rail at the bottom and undo the bolt then looses the strap off the rail.
Pull off the cover that you pull to move the seatbelt up and down (seriously just pull it off it will come).
Undo the small torx bit under the cover and take off the other plastic part that loosens.
Undo the nut so the seatbelt falls off this part.
Then you have to remove the passenger seatbelt but first go into the boot and locate two small torx bolts on the C pillars (near the interior light on the passenger side) which will enable you to remove the whole C pillar.
Go into the passenger seats and see where the seatbelt is attached at the bottom, remove it.
Pull the B pillar off where you undid the front seatbelt.
I would advise taking the rear seat benches out (not the back panel) will make it a lot easier.
At this point the rear door cars should have nothing else obstructing it's way to come out so just pull it and pop it out.
Then obviously to re attach it's the same in reverse.
acotton21
PostPosted: Thu Jun 16, 2011 4:10 am Reply with quote Up
cheers lads ill be hopefully doing them on sunday
Bassline_Toad
PostPosted: Thu Jun 16, 2011 4:58 am Reply with quote Up
First time doing it is a pain in the ass!
You have to take damn near everything off Razz
  Quick Reply
Username:
Message:
Quote the last message
