Online Now [71]:
Visitors: 70
Today: 17986
Total: 116972001
Forums › The Car › 206 Problems › 206 hdi flat battery
valdice
PostPosted: Tue Jun 14, 2011 2:01 pm Up
Hi all
I have a 2006 1.4 hdi and have a strange problem.
When i stop the car the battery symbol on the dash stays on. if I leave the car for 2 days the battery goes flat. I charge it up, the car runs fine and the battery symbol goes out when I start and drive the car, and it drives fine. when i stop the battery symbol is there again and flat battery city here we come. Also the locking on the key is intermittent some days it works some days it does not. I have tried disconnecting the Alternator to see if it is somehow feeding back through to the battery symbol, but even with the Alt disconnected the the symbol stays on.
Any ideas anyone??
Mad Mad
GARAGE OWNER
Antknee
PostPosted: Tue Jun 14, 2011 2:25 pm Up
Check all the earths, these cars are notorious for bad earths lol i have had 2 problems with them in the last couple of years, one of which sounds very similar to yours
PostPosted: Wed Jun 15, 2011 8:43 am Up
Check you have the correct stop / tail bulbs fitted in both rear clusters & there fitted in the correct way round.
valdice
PostPosted: Thu Jun 16, 2011 2:18 am Up
Hi thanks for that
tried the bulbs there all correct and working.
A little more info.... when you turn the ignition off as I said the battery symbol, mileage and clock all stay on even with the key out and they stay on it does not matter how long you leave it. Locking does not work but car restarts and runs fine and everything works. if you leave it like this the battery goes flat. If you disconnect the battery for a minute everything is OFF when you reconnect and the locking all works off the buttons on the keys without re syncying it?? Start the car and stop it and it all does the same , clock mileage and battery warning on. obviously the ignition is not being turned off somehow
help this is my daily car and i am getting fed up with taking the battery off at night.
Evil or Very Mad
GARAGE OWNER
pudgie
PostPosted: Thu Jun 16, 2011 7:21 am Up
is the interior light switch dodgy
does it go off after the door is closed
my other cars a delica
Ali_H
PostPosted: Thu Jun 16, 2011 7:23 am Up
Sounds like you have a drain somewhere, have you got any aftermarket audio fitted?
kurtis wrote:
valdice
PostPosted: Sat Jun 18, 2011 3:32 pm Up
No
The interior light is working fine and
The radio is standard. The drain is because
The ignition is being kept live by something
GARAGE OWNER
PostPosted: Sun Jun 19, 2011 4:56 am Up
Reboot the BSI correctly.
If that dont fix it then of to a Peugeot main dealer you go.
