Latest: Worthy967
Overall: 17143
Online Now [89]:
Visitors: 88
Today: 41196
Total: 114338752
Forums › The Car › 206 Talk › 206 SW 2.0 HDI Car Alarm Problem
skyking_comms
PostPosted: Fri Jun 17, 2011 11:13 am Up
Hi,
A while ago a neighbour complained that my car alarm was going off during the night. I never heard it so presumed it was someone elses. Last night at 1am I heard it go off, there was no one around and the car and windows were fully closed. Then at 3am it went off yet again! I had already dearmed and the rearmed the alarm at 1am so there's a fault somewhere. The weird thing is it hasnt gone off during the day (well not that I know off)
Any ideas? Is it an electrical fault?
Thanks,
Darren
PostPosted: Fri Jun 17, 2011 11:16 am Up
Arm the alarm system with the ultrasonic sensors switched off & see if that stops the alarm being triggered.
Ultrasonics are a common problem & there cheap new from a Peugeot / Citroen main dealer & easy diy to replace.
skyking_comms
PostPosted: Fri Jun 17, 2011 2:48 pm Up
Stupid question.. how do you switch the sensors off?
PostPosted: Sat Jun 18, 2011 2:15 am Up
RTFM Wink
Turn the ignition off
Press & hold the button by the handbrake until the red alarm led comes on & stays on.
Now just exit the car & lock it as normal with the remote, the alarm led will now flash as normal.
You have to press the button everytime you wish to disarm the ultrasonics & arm the alarm system.
skyking_comms
PostPosted: Sun Jun 19, 2011 2:36 pm Up
Thanks for the instructions. I havent yet tried them as the alarm hasnt gone off since. Its definitely a intermittent fault. How difficult is it to replace the ultrasonics? Im thinking of just changing them if they are a common fault.
Darren
BobbyD
PostPosted: Mon Jun 20, 2011 2:26 am Up
The hardest part is disconnecting the brown plug under the BSI unit Laughing
Basically the wiring goes along the front of the headlining & both wires then go down the drivers A pillar to the connector plug under the dash in the BSI unit.
A few little torx screws & some clips that hold other trim parts on.
