Latest: SA01
Overall: 17138
Online Now [294]:
Visitors: 293
Today: 67959
Total: 111314312
Forums › The Car › 206 Problems › how much movement should there be?
spud_owen
PostPosted: Sat Jun 18, 2011 5:44 am Up
how much movement should there be in the gear box engine mount? ive got abit of movement from somewhere and although this replaced mount a couple of months ago i think it might have gone again. i removed it today and took some photos see below, is this worn or deos that seem about the right ammount of movement to have photos show the metal section in the extreme right and the extreme left position.
cheers mark
Honda Accord cdti....205GTI
LACEY AND OWEN ARCHITECTURAL SERVICES
www.laceyandowen.co.uk
NICKST
PostPosted: Sat Jun 18, 2011 5:52 am Up
That looks about right to me did one on a customers car this morning looks the same.
spud_owen
PostPosted: Sat Jun 18, 2011 6:08 am Up
so it should be alright? must be the bottom mount moving them, top mount is fine how do you tell if the bottom mount is gone?
PostPosted: Sat Jun 18, 2011 6:11 am Up
the bottom mount seldom break at all....
PostPosted: Sat Jun 18, 2011 8:09 am Up
not sure that looks right can you move the metal collar with your fingers it should hardly be able to move
PostPosted: Sat Jun 18, 2011 8:20 am Up
Just looked at my old mount and when I remove the metal sleeve, the oval hole is 30mm long.
spud_owen
PostPosted: Sat Jun 18, 2011 11:28 am Up
yeah i could move it left to right as the pictures, proably about 5mm from the centre each way, also should be metal sleve be wedged in the rubber as i coud take it out very easily?
spud_owen
PostPosted: Sat Jun 18, 2011 11:29 am Up
i know they dont but just trying to sort the car all the little bits are doing my head in!!
spud_owen
PostPosted: Sat Jun 18, 2011 11:31 am Up
cheers will measure mine if i take it off again, its not a difficult job but you got o undo so many bolts!!!
