Posted: Sat Jun 18, 2011 7:26 am |
I thought my battery had died and needed replacing, so i checked it with a multimeter and it's coming up with between 11.2 and 12.6 v.
This made me think it could be the starter motor, I have no idea where that is on my car, but i'd read if you put the car in high gear and rock it back n forth it can jolt the starter in to starting so i did that....
still doesnt start and now comes up with economy mode on the read out....
maybe time to bite the bulliet n let a garage sort it $$$$$
Posted: Sat Jun 18, 2011 7:29 am |
alternator mate??? the voltage is a bit low if i remember rightly.. someone will correct me if im wrong.
| Tivoli LX 1.1
Black GTI 180
White VXR Burg | |
| liam180 wrote: |
If you RTFM you will find thats perfectly normal, you need to start the engine to get it back out of economy mode
Posted: Sat Jun 18, 2011 7:32 am |
RTFM? - read the f*****g manual? Ha.
| 2001 1.4lx
PrePlexed 5 door. | |
Posted: Sat Jun 18, 2011 7:37 am |
Come on! if half the people on here RTFM there wouldnt be a forum!
And with the starter sounding like it's gone i don't think it's going to start to easily.
Posted: Sat Jun 18, 2011 7:42 am |
If I have any of the electrics on for more than 20 mins without starting the car economy mode shows
Posted: Sat Jun 18, 2011 7:59 am |
have you tried bump starting the car
| 2003 Pug 206 2.0 GTI 180
IT TAKES TALENT TO BE THIS NOOB!!!! | |
Posted: Sat Jun 18, 2011 11:48 am |
yeah, but the battery still seems to die after a while. im guna give it a good charge n see what happens
Posted: Sat Jun 18, 2011 12:02 pm |
yup economy mode active is just when youve had the electrics on for a certain amount of time without firing the engine up
Posted: Sat Jun 18, 2011 12:20 pm |
If the battery voltage is below 12.25V with ignition-off, it's had it.
With engine running it should be around 14V if the alternator is working correctly.
Posted: Sun Jun 19, 2011 4:55 am |
| liam180 wrote: |
| yeah, but the battery still seems to die after a while. im guna give it a good charge n see what happens |
Just go & buy a new battery, your gonna end up replacing it anyway as this one sounds f****d
Posted: Sun Jun 19, 2011 5:05 am |
gett the car started leave it to tick over and put a multimeter on to the battery termals and see what teh voltage is it should be over 13-14v
Posted: Sun Jun 19, 2011 5:08 am |
worst way.... go to a garage and get them to do a drop test on it.....
We drop test batteries we suspect are duff....... straight in the skip
Posted: Sun Jun 19, 2011 5:12 am |
| macj wrote: |
We drop test batteries we suspect are duff....... straight in the skip  |
Hope your collecting them up & recycling them responsively, there worth a bit of money if you have enough to weigh in
Posted: Sun Jun 19, 2011 5:23 am |
| MrBSI wrote: |
| macj wrote: |
Hope your collecting them up & recycling them responsively, there worth a bit of money if you have enough to weigh in  |
We have an enviromental policy at Essex Motorsport to recycle as much waste material as possible..... this means weighing it in
