Latest: sparrowdclxvi
Overall: 17139
Online Now [111]:
Visitors: 110
Today: 129051
Total: 112940524
Forums › The Car › 206 Problems › suspension top mount failure??
dannyN
PostPosted: Sun Jun 19, 2011 11:34 am Up
Hey, i recently changed both front shocks on my gf's 206 and noticed the drivers side top mount bearing is knackered ive put it all back together and i can wobble the top mount with my hand from reaching up behind the wheel, Is this something to be "overly" concerned about as my gf needs the car but im un sure whether to let her use it untill the mount is fixed?
please and thank you:)
PostPosted: Sun Jun 19, 2011 11:43 am Up
If it was knackered, why did you put it back together? I would replace it before she drives it, you dont really want it to fail at speed.
dannyN
PostPosted: Sun Jun 19, 2011 12:21 pm Up
ok thanks. i only put it back together to move it from my garage block.
PostPosted: Sun Jun 19, 2011 12:28 pm Up
just get a new one then.
they tends to break overtime
dannyN
PostPosted: Mon Jun 20, 2011 4:48 am Up
yea ordered one now just wasnt sure how urgent it was and wanted some one to back me up so she wouldnt drive it lol
PostPosted: Mon Jun 20, 2011 6:10 am Up
I'd have ordered two new ones.
PostPosted: Mon Jun 20, 2011 7:50 am Up
If I was changing both front shocks I would have ordered up 2 new top mount bearings, seems stupid putting the old ones back in seeing how cheap new bearings are.
