Posted: Sat Jun 11, 2011 9:31 am |
Ola ladies n gents,
Just a quick question, does anyone have an issue with there car stalling randomly whilst driving??
Happens normally when i break and change to a lower gear at the same time. Happened today n lost all steering whilst turning left at a junction
there's no indication of it stalling just cuts out and have to turn the ignition again
Any ideas??? Please
Posted: Sat Jun 11, 2011 9:35 am |
mine stalls when i reverse off the drive and stop, the car cuts out, but then start up and is fine. happens 2/3 times a month and early in the morning. but never while driving.
| Abs
Peugeot 206 1.6 Sport (55)
Audi A1 2.0 TDi Sport (14) | |
Posted: Sat Jun 11, 2011 9:38 am |
Mine has done that a few times in the two years Ive owned it and so has my cousins one =/ never found out what it is to be fair.
Kinda scary when the steering locks though!
Posted: Sat Jun 11, 2011 9:40 am |
yup, good job nothing was coming!!
Posted: Sat Jun 11, 2011 9:41 am |
| keeno wrote: |
No you didnt, you simply lost the power assistance
| dopey wrote: |
Steering wont lock unless the ignition key is removed from the barrel.
Posted: Sat Jun 11, 2011 9:42 am |
| MrBSI wrote: |
| keeno wrote: |
| dopey wrote: |
Steering wont lock unless the ignition key is removed from the barrel. |
felt like i had lost steering all together
Posted: Sat Jun 11, 2011 9:50 am |
it just goes really stiff because your having to manually drive it + the pump.
happens to me very occasionally, its annoying as hell lol
Any work you undertake as a result of my posts is done so at your own risk  | |
Happens to me aswell quite rarely though, but what a b*****d when it happens
Posted: Sat Jun 11, 2011 9:54 am |
| Razpulsedj wrote: |
| Happens to me aswell quite rarely though, but what a b*****d when it happens |
any ideas wat it is?
Posted: Sat Jun 11, 2011 9:56 am |
no idea, not something to do with the air intake though. must be the ECU or fueling
Posted: Sat Jun 11, 2011 9:59 am |
| MrrNoName wrote: |
| no idea, not something to do with the air intake though. must be the ECU or fueling |
Very strange!!
Posted: Sat Jun 11, 2011 10:16 am |
well for it to cut out, its like there's a lack of power to the car from the battery so maybe something along those lines?
Posted: Sat Jun 11, 2011 12:26 pm |
| Razpulsedj wrote: |
| well for it to cut out, its like there's a lack of power to the car from the battery so maybe something along those lines? |
Arh ok, ill ava look
Tomoz, tho gunna b honest not got a clue wat im looking for!!
Posted: Mon Jun 13, 2011 4:50 am |
mine does this, revs drop really low when putting the clutch in then sometimes will just stall, bad for when changing for a corner! It's my ICV as i was told to clean it a while ago and it just got worse after that eventually sometimes starting and it idling at 3000rpm!
Posted: Mon Jun 13, 2011 7:04 am |
| jedwards wrote: |
| mine does this, revs drop really low when putting the clutch in then sometimes will just stall, bad for when changing for a corner! It's my ICV as i was told to clean it a while ago and it just got worse after that eventually sometimes starting and it idling at 3000rpm! |
if its your ICV just change it, it takes less then 5 minutes and you can get one on ebay for about £18 that works fine, problem is that some of us already have changed it (from the stealers! total rip off lol) and the problems exactly the same.
