Latest: flipflap
Overall: 17140
Online Now [273]:
Visitors: 272
Today: 38455
Total: 113945538
Forums › The Car › 206 Problems › Bsi Removal/Replacement Assistance required
russjo
PostPosted: Wed Aug 31, 2011 7:24 am Up
Have to replace the Ecu and Bsi units including the ignition barrel and transponder (already purchased). Does any one have any help or advice on removal/replacement of the Bsi unit?
iainlovatt
PostPosted: Wed Aug 31, 2011 7:42 am Up
would of thought there will be a few people on here this evening who will be able too! Smile
(My Garage)
PostPosted: Wed Aug 31, 2011 9:44 am Up
Why have you bought the ignition barrel and the transponder ring? Confused
You need the BSI, ECU and transponder from the key
Or just the BSI, and get the IMMO code matched to your existing one and re-code the keys
Or get the BSI, and remove the IMMO from the ECU
PostPosted: Wed Aug 31, 2011 9:48 am Up
Me and Lee would help you,but I'm farrrrr away,and Lee might be busy ;),what you think Lee?
PostPosted: Wed Aug 31, 2011 4:13 pm Up
For a first post its pretty dodgy Wink
russjo
PostPosted: Thu Sep 01, 2011 10:00 am Up
The key,barrel and transponder ring came with the Bsi and Ecu! Paid £80, which I thought was a good deal.
Have managed to remove/replace Ignition barrel, Bsi and Ecu.
Followed steps to re-set the Bsi but hasn't seemed to have re-set as the old milage is still showing as 46958 and sport and ice lights are alternating on dash! What else can I try?
