Posted: Sun Jun 19, 2011 11:12 am |
Hey my speedo is going absolutely haywire. Sometimes it will work 100% for a few minutes, then all of a sudden it will not be as nippy and the needle will drop to 0, when the speedo kicks back in and says my speed the power seems to return?! Anyone heard of this before.
Posted: Sun Jun 19, 2011 11:18 am |
2Oh!6 wrote: |
Hey my speedo is going absolutely haywire. Sometimes it will work 100% for a few minutes, then all of a sudden it will not be as nippy and the needle will drop to 0, when the speedo kicks back in and says my speed the power seems to return?! Anyone heard of this before. |
This happened to mine and it was the speedo motor inside the cluster... I replaced it and it now works perfectly
Posted: Sun Jun 19, 2011 11:34 am |
Trade Rating: +45
If needed i have a speedo unit. It is multiplex and from a gti if it helps. Cheers
| PAST -2008 Vauxhall Astra VXR / 2002 pug 206 GTI
Now have my 106 GTI track car
TEAM - I HATE FACEBOOK | |
Posted: Sun Jun 19, 2011 11:36 am |
meady wrote: |
If needed i have a speedo unit. It is multiplex and from a gti if it helps. Cheers |
No use for the OP's non plexed 206
Posted: Sun Jun 19, 2011 3:37 pm |
Trade Rating: +45
Didnt realise his was non plex
Posted: Tue Jun 21, 2011 2:21 am |
xspongerx wrote: |
2Oh!6 wrote: |
This happened to mine and it was the speedo motor inside the cluster... I replaced it and it now works perfectly | Cheers, will go pick one up asap.
