Posted: Sun May 22, 2011 4:25 am |
The partners car has been showing unblock filter for ages now i have scanned it for codes this morning and this is what i got.
P1435
P2408
P1351
Any ideas on how to fix this.
We had the elios fluid topped up last year but it didnt stop the problem.
It also hunts on idle, and feels very slugish compared to when it was new
Posted: Sun May 22, 2011 4:26 am |
Im going to order some glow plugs to see if that solves one onf the codes. but i think they are all related.
Posted: Sun May 22, 2011 4:27 am |
erm, the filters probably blocked? if its too blocked to regenerate, topping up the fluid wont change a thing because its already got too bad. get a forced regeneration done on the DPF, and if its still not unblocking its new DPF time.
EDIT: the sluggishness and bad idle could also be due to the restriction in the DPF depending on how blocked it is
Any work you undertake as a result of my posts is done so at your own risk | |
Posted: Sun May 22, 2011 4:42 am |
Just remove it.
Posted: Sun May 22, 2011 6:29 am |
Trade Rating: +59
MrrNoName wrote: |
EDIT: the sluggishness and bad idle could also be due to the restriction in the DPF depending on how blocked it is |
Could try steam cleaning it, might clear it out enough to allow regeneration.
| '98 Nile Blue 306 GTi 6
'04 Obsidian Black 206 GTi 138 | |
Posted: Sun May 22, 2011 8:33 am |
G. wrote: |
MrrNoName wrote: |
Could try steam cleaning it, might clear it out enough to allow regeneration. |
Did you end up doing that? Did it work?
Posted: Sun May 22, 2011 8:54 am |
Trade Rating: +59
Need to sort out my fuel cap sensor first to find out.
Posted: Thu Jun 23, 2011 7:38 am |
How did you get on with sorting the problem ?
Posted: Thu Jun 23, 2011 9:48 am |
_LiJ_ wrote: |
How did you get on with sorting the problem ? |
G. bought a petrol powered car instead
Posted: Thu Jun 23, 2011 11:12 am |
Trade Rating: +59
MrBSI wrote: |
_LiJ_ wrote: |
G. bought a petrol powered car instead |
